Abs speed sensor help!!
Irierasta
New to the forums! I was wondering if I'd need to bleed any lines after removing the speed sensor located at the top of my differential housing?
My rear anti-lock light is also on... Was told could be the sensor has metal fragments stuck to it due to it bing a magnet...don't know much about abs if the sensor trick don't work I gotta take it in!
1995 Toyota 4runner
4wd 3.0l v6
Almost 94,000 miles
Alright thanks! I wasn't to sure when I saw oil leaking as I removed the bolt to hold it down. ( prolly the differential oil)
And yes it feel like it has a little to much play kinda sensitive... But I redid the front rotors, calipers, pads, brake lines. I also tookthe back drums apart just cleaned the dust and adjusted them. Mayb I gotta bleed them better??
