Old 03-19-2012, 10:59 PM #1
combatmedic combatmedic is offline
Banned
combatmedic is on a distinguished road
Banned
Headlights suck, brightest foglights you guys recommend?
Like the title says, my headlight output is worthless, I'd like to invest in a quality foglight setup, the only name brand I recognize is Hella, any one have any recommendations?
combatmedic is offline   Reply With QuoteReply With Quote
Old 03-19-2012, 11:03 PM #2
nashville67's Avatar
nashville67 nashville67 is offline
nashville67 is on a distinguished road
i had a set of procomp 55s good lights but i have kc daylighters on both of my trucks piaa is also an opiton or u could up grade your headlights
[SIZE="3"][SIZE="4"]88 4runner trail truck ifs snorkle with new 22re with lce header
84 extend cab with 22 trail gear bumper and tube doors 3 in rough country lift and 35s daily driven
88 suburban crate 502 tow rig
67chevelle ss with 396 graduation present
nashville67 is offline   Reply With QuoteReply With Quote
Old 03-19-2012, 11:07 PM #3
jirehn jirehn is offline
jirehn is an unknown quantity at this point
I think Hella will do, They have a great performance.
Saturn
jirehn is offline   Reply With QuoteReply With Quote
Old 03-19-2012, 11:10 PM #4
Bad_Vision's Avatar
Bad_Vision Bad_Vision is offline
Bad_Vision is on a distinguished road
Bad_Vision's Avatar
Get a HID kit. You have a second gen right?
Classic's Section Moderator
http://www.4crawler.com/4x4/CheapTricks/index.shtml
My 1985 TDI swapped 4Runner http://www.toyota-4runner.org/classi...-tdi-swap.html
Bad_Vision is offline   Reply With QuoteReply With Quote
Old 03-19-2012, 11:23 PM #5
1st.Gen.Runner's Avatar
1st.Gen.Runner 1st.Gen.Runner is offline
1st.Gen.Runner is on a distinguished road
i got 4,600k blubs in my 1st gen and took my fogs off
2001.5 S4 AVANT STAGE 2+
1988 4RNNER
31x10.5 DuraTracs+T-Bars
1st.Gen.Runner is offline   Reply With QuoteReply With Quote
Old 03-19-2012, 11:27 PM #6
Bad_Vision's Avatar
Bad_Vision's Avatar
they make HID fog lights too
Old 03-20-2012, 12:18 AM #7
Banned
Banned
Ok cool, I have an HID set I bought for my motorcycle that I never got around to installing... maybe it'll fit in the 4runner, and yes Im talking about the 1995
Old 03-20-2012, 12:24 AM #8
willyt4r's Avatar
willyt4r willyt4r is offline
Real Name: Willy
willyt4r is on a distinguished road
willyt4r's Avatar
Real Name: Willy
Hella sealed beam replacement
Might I suggest a sealed beam replacement.
hers is one:
Headlamp Bulb
or a cheap ebay version:
SEALED BEAM DIAMOND-CUT PROJECTOR HEADLIGHTS CONVERSION REPLACEMENT LH+RH | eBay
willyt4r is offline   Reply With QuoteReply With Quote
Old 03-20-2012, 12:29 AM #9
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold
rickashay's Avatar
Real Name: Addison
Or I could make you some of these!
Untitled by Headlight Hookup, on Flickr
Morimoto Mini's in 7x6 sealed beams...
rickashay is offline   Reply With QuoteReply With Quote
Old 03-20-2012, 02:48 AM #10
T?@\7 T?@\7 is offline
T?@\7 is on a distinguished road
If you need better headlamps, foglights won't fulfill your needs.
Check out roundeyes.com, they make headlights housings WITH the option to upgrade/ change bulbs. A better choice if your headlights suck like most.... and Hella does make good foglights, i have the black magic 500s and they basically fill in where my high beam would be.
1987 dlx
SHAKKA
Originally Posted by SCRunner12 View Post
Where's T?@\7 at? He's always talking about bong rips in his posts. I thought he would be all over this post by now.
T?@\7 is offline   Reply With QuoteReply With Quote
Old 03-20-2012, 06:22 PM #11
Banned
Banned
Wow you guys have thrown in awesome suggestions, I think I'll go w/ a pair of these Rectangular Toyota® Conversion Headlamps - Toyota Headlamps by Roundeyes™ Inc.
and fog lights.
Old 03-20-2012, 07:55 PM #12
hoe_nah hoe_nah is offline
hoe_nah is on a distinguished road
If u got a 95 those wont work...well it could with some Fab n a new grill...
92-95 got composite lenses and they are different shape, I'm in the process of getting my 95 back to the square ones so I can do a retrofit...I had my retrofit in the flueted lens and it worked but the cutoff wasn't sharp
hoe_nah is offline   Reply With QuoteReply With Quote
Old 03-21-2012, 02:52 AM #13
and fog lights.
By the sounds of it(besides fitment), you'll be happy with that setup. The trouble now is figuring out which bulbs to put into the housings... the ones that cone with it are standard, not at all brighter than stock.... FYI. Like I mentioned, I have the hella black magics which put out a much whiter and brighter light. Prob just need to match power and spectrum(any ideas?). good luck
1987 dlx
SHAKKA
Old 03-21-2012, 10:25 AM #14
Banned
Banned
I have a set of 6k HIDS on our 3rd gen 4runner and honestly its too blue for my liking and the output is bright, but can't see as well as say oem halogens. I think I'll just put in a set of sylvanias, and get the fog lights and be done with it.
Old 03-22-2012, 10:05 AM #15
csrobb007's Avatar
csrobb007 csrobb007 is offline
csrobb007 is on a distinguished road
csrobb007's Avatar
I've run into the same problem with my 94...no conversions available (at least for the housing), bulb upgrade is all I've found. HID Nation makes a decent kit to upgrade the 9004 bulb to HID, but other than a complete grill, housing, and turn signal fab/replace, I havn't found a "diamond" lens install. Wife got me a set of KC's (630 kit) that work great for long range lights, but in traffic and around town (low beams), my lights still suck.
It is perfectly acceptable to yank a tigers tail...as long as you have a plan to deal with his teeth.
csrobb007 is offline   Reply With QuoteReply With Quote
All you 4th gen guys with lifts suck!....lol momo.75 4th Gen T4Rs 48 12-15-2011 12:21 AM
I know that I am not the brightest bulb in the box...BUT.. coltonk Classic T4Rs 11 09-07-2009 10:16 PM
Wetsanded My Headlights & Foglights ***56k Warning*** Tego 4th Gen T4Rs 22 04-20-2009 07:44 AM
2005 4runner price decreasing??? SUCK! SUCK! SUCK! X5Runner 4th Gen T4Rs 21 02-27-2005 01:26 AM
Can the foglights be turned on w/o the headlights? 4RNR4BB 3rd gen T4Rs 5 02-26-2005 08:06 PM
