Upper Plenum powder coat
willyt4r
Had to replaced the passenger valve cover gasket. While i had the top end off i replaced all the by pass hoses and vacuum hoses. A guy at work does powder coating just to dress things up under the hood.:peace:
no a professional shop
A friend at work - his family owns a shop in Ontario California.. $ 50 bucks:bluejump:
powdercoated Plenum Installed
Finally had the time to install my Powdercoated Plenum and water intake tube.
Wasn't a hard job just tedious. If and when I have to take off the plenum again I would inatall the PAIR Valve hose before attaching:jump: the Plenum
i find spraying some hi temp header paint in a dixie cup and using a q tip is a great way to get the bolts to match or offset color them.
RIALTO.....
may pick your brain when I change my gaskets...
Drivers side is leaking... :hello: haha
Helo Jonny Redlands
I will be more to help. The drivers side is easy- no need to remove the Plenum. I am free most weekends and afternoons. I like Stella
:p sweet. Checked it out yesterday, seems that only my drivers side is leaking.
Rialto is super close. We should go wheeling sometime:lookout:
e-locker.?
pretty schnazzy dude! I am impressed. I am still open/open & lifted with km2's. Need to lock the rear soon!
