07-11-2013, 12:42 AM
Buying my first 1995 4Runner
hi there I am buying a 95 4Runner SR5 2wd with 141,000 miles from a Co-worker of mine, but I have noticed a couple of issues with the steering gear box on the passenger side and a real bad oil leak coming from between the engine and trans.. are these common issues? easy to fix? also where can I buy that gear box
07-11-2013, 03:20 AM
Real Name: Kevin
Real Name: Kevin
Steering gear box on the passenger side? Are you talking about the idler arm? Any parts store will have one.
Oil between the motor and trans could be as simple as a leaky valve cover and a 1/2hr fix, and it could be a bad rear main, which is a decent size job. No way to find out without getting in there and finding out.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
07-11-2013, 10:38 AM
I just wasnt sure what to call it my friend said it was the Rack and pinion leaking..when ever I went to go look at it i did notice somthing leaking that was bolted to the driver side frame that was also hooked up to some steering parts..
07-11-2013, 11:14 AM
Real Name: Kevin
Real Name: Kevin
You're contradicting yourself, is it on the passenger side or the driver's side? Your steering box is on the driver's side. The idler arm is on the passengers side.
Are you sure it's the steering box leaking, and not the power steering pump above it?
07-11-2013, 11:42 AM
If you are not a mechanically talented person then a 2nd gen 4runner is not the vehicle for you.
1995 4Runner 4x4
3VZ-E, Auto, 2" lift, 33"s on 15x8's, 4:88 gears
07-11-2013, 12:20 PM
meant to say its on the passenger side not driver side.. I will be meeting the guy today and I'll takes some pictures of it to post
07-11-2013, 05:25 PM
Well i guess it isnt the idler arm but still not sure what it is
07-12-2013, 04:08 AM
Real Name: Kevin
Real Name: Kevin
3VZE trucks are weird.
Your second pic has the idler arm in the lower foreground. That's not what's leaking though, there's nothing in the idler to leak really. I'm not familiar with the 3.0 engine bay, but it looks like that's the power steering pump above it with all that crud on it? That's probably what's leaking.
07-12-2013, 05:11 AM
Your right Kid. The idler arm is almost directly below the power steering pump. If he has power steering fluid and not ATF in there is could be a major part of the problem (as always, I had to experience such a mistake to know this).
Originally Posted by dorton
I wish I had a 2nd gen.
Originally Posted by BucknutBob
I find myself wishing I had waited and picked up a 2nd Gen instead
Originally Posted by KidVermicious
I want to convert my '85 to IFS.
I'm making this my new signature!!!
07-12-2013, 05:16 PM
Glad you like that quote... I speak from experience
1995 4Runner 4x4
07-13-2013, 01:12 AM
As do I.
07-13-2013, 01:34 AM
lol you guys are too funny.
that thing thats leaking is the ABS pump/unit. most people take it out but dont ask me how, i dont know.
your other leak between engine and trans is the rear main seal. i would do the trans input shaft seal as well
07-15-2013, 12:20 AM
Finally someone with a real answer.. I appreciate the help sir and hope to get this great vehicle in the road again..
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
1995 4Runner SR5 V6 4WD
zonian91 |
New Members |
5 |
05-27-2013 10:21 PM |
1995 4runner
Bear_F_ucker |
General Discussions |
6 |
01-01-2012 08:50 PM |
1995 4runner v6
bowtiedmax |
Problems & Warranty Issues |
0 |
10-21-2009 09:06 AM |
1995 4Runner
jmrwd3 |
Classifieds - buy & sell (no commercial ads please) |
3 |
09-10-2009 10:35 AM |
1995 4Runner 2WD V6
E4L |
3 |
07-09-2009 09:26 AM |
