what size coils for zuk mod
ncgyver
I have an 87 Stock T4R ready for a zuk mod. What size coils for a non welding mod would work best ? Gonna do it as I change out my shocks.
i used rear coil from a 96-98 4runner. it was no weld or cut install.
took care of the sag and gave me a lift too. you can cut the spring down to just take care of the sag. if you keep it stock height, i would get some factory or replacement shocks. if you dont cut the coil and enjoy the lift it gives, look at getting some OME shocks
I just want Soften the jolt and take the sag out .
I used a 125 lb 14inch coil and it gave me about 2 inches over stock. If you're just looking to get back to stock height, I'd use a 12in 100lb coil. They're about $30 each from Southwest Speed on Ebay.
Ok Thats what I was looking for. I have to haul my water to the house so I either pull a trailer or I have a 35 gallon tank in a hitch basket. It bottoms out on the bump stop as is. I'm looking at Putting on Rough Country shocks on all fours and doing the zuk mod. very Soon.
Go to WWW. gearinstalls.COM scroll down to bottom left hand side of page there is where you will find the zuk mod listings. I used the 12" 100 springs and NOW IT SITS 1.5 INCHES ABOVE STOCK HIGHT SO I ORDERED BALL JOINT SPACERS TO LEVEL IT OUT AND i love the ride now. It also has video of how to do it
DJNutshell
