Old 09-22-2013, 12:33 AM #1
aceseverywhere aceseverywhere is offline
aceseverywhere is on a distinguished road
3vze thermal vacuum valve. need help
Will the truck work without this TVV thing. Because both nipples broke. And can anyone explain to me how this thing works. Would it be bad if i just bypassed it. what if i where to connect the the charcoal can straight to the plenum? would that work????
please bestow me with your knowledge.....
3vze thermal vacuum valve. need help-tvv-jpg
aceseverywhere is offline   Reply With QuoteReply With Quote
Old 03-27-2023, 12:21 PM #2
pishta68 pishta68 is offline
pishta68 is on a distinguished road
these are color coded so in theory you should be able to find another like blue one (Rock has them in blue, $$$!) or Ebay (~20) but running the canister straight to the intake is not a good idea as it will be drawing vapor (ie vacuum leak) even when cold and that may not be good for warmup. It needs to be warm to open this valve to then open the purge control valve that allows stored vapor to then be drawn into intake. If this operates a purge control valve, then you can tee this off another thermally ported vacuum fitting and it will operate only when warmed up. I have a white one for purge control and a blue one for EGR, 2 different temp ratings....?
pishta68 is offline   Reply With QuoteReply With Quote
Old 03-27-2023, 08:30 PM #3
SaulG's Avatar
SaulG SaulG is offline
SaulG will become famous soon enough
SaulG's Avatar
If you have all the broken parts..a "fix" is to insert a straw from spray can (cut to fit) and super glue it back together, it works.!
Or shop 90925-05047 iirc? is for the TVV 50~108 $$.
SaulG is offline   Reply With QuoteReply With Quote
3vze thermal vacuum valve. need help aceseverywhere 3rd gen T4Rs 0 09-21-2013 10:42 PM
3vze vacuum hoses and check valves bomhour Classic T4Rs 9 06-29-2012 01:13 PM
93 toyota 4runner 3vze vacuum line diagram Turbomrdeuce Classic T4Rs 1 07-25-2011 09:58 PM
vacuum line routing 95 3vze 4runnintexan General Discussions 0 05-03-2008 08:39 PM
