Originally Posted by S61Dan
Got the pitman arm halfway up the steering box with hitting it and using an impact gun, she will not go any further
yep, that pic looks normal.
as long as you can get it on far enough to use the lock washer, it should be good.
you will NEVER get it back to the original location.
I have a very strong impact here at work, and mine is still about 1/8" lower than original. and I REUSED the pitman arm. so its the same one, not a new/different part.
im not sure what the factory uses, but its much stronger than we have access to.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
