Front Range Offroad Crossmember and Skid
The Front Range Off-Road Fabrication Crossmember is a great solution for many problems plaguing Toyota Trucks and 4runners. By mounting from the back side of the transfer case, driveshaft interference with the front drive shaft (on dual case equipped trucks) is eliminated. It also allows positioning of the transfer case in the optimum spot depending on your specific needs, by allowing you to easily raise or lower the transfer case. On motor swaps, the t-case may be relocated front to rear as needed. When the FROR Crossmember is combined with the FROR Skidplate, ground clearance gains of over 3" can be obtained without relocating the transfer case.
Get yours today at Front range crossmember-skidplate combo
