Real Name: Ron
Real Name: Ron
Good tires (you can fit 33x10.50x15's on there with minimal or no rubbing) and good driving will get you a long way. The 2nd gen 4runner is a pretty capable offroad vehicle right out of the box - good ground clearance, short wheelbase, narrow, good low gears.
That being said, the 2nd gen IFS doesn't have a lot of travel, so my biggest problem was deep diagonal water breaks across an uphill stretch of trail. The suspension would get crossed up, a wheel on opposite corners would lift, and I would stop moving.
I solved that by putting the Aussie locker in the front. Completely eliminates that issue, and the truck will pretty much go anywhere now. I think a locker is a better solution than the SAS, plus it's an easier mod. The SAS will reduce the wheel lift problem, but won't eliminate it. The locker will make wheel lift irrelevant.
But, I too would first encourage you to run the truck as is and explore its limitations based on your needs. It may well do everything you want.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
