Granny - SOLD
4RunnerAquasport
Hello Classic Folks! Just getting started on a thread for my recently purchased 1988 22RE Auto. I affectionately call my 5th gen "LE MAE", so meet "GRANNY". Cornball factor of 10, but I treat these trucks like family. Lean on em hard but always take care of em! Gotta do some research and see what package and options came on her.
Nice truck! Auto tranny is a dog and expensive to fix but manual swap is easy when that happens. Congrats
Sent from my XT1635-01 using Tapatalk
Thank you Sir! And yeah Lol, as long as there is no uphill or headwind, click the ECT to power and OD off, it does OK. The Florida boys are already hittin me w the SAS and W56 recommendations lol. Oh the money I could spend.
Sas is a must for offraod but if your not going to trail ride it a lot then keep the IFS just be prepared to replace all sorts of ball joints and tie rods every 2 years.
W56 with a VW turbo diesel is easy and a great option along with the 3.4L when the time comes to do engine work both are great and reliable!
Yes sir! I saw the you tube mason jar test on that diesel awhile back. Pretty cool stuff. I'm partial to the 3.4 though, my buddies Tacoma is running brand new and still powerful at 208K. Already looking at SAS down the road too lol. Pretty good Yota community here in Fl.
fb page devoted to trucks and 4runners for sale as well as parts. Lot of axles go through that page. Right now the old girl is gonna get a tune up and a safety once over to be a DD. I've gone Group Buy crazy grabbing up a Dual Shock Total Chaos kit w the LCAs and King secondaries for my 5th gen. So while LE is being worked on GRANNY gets the DD duties. I may shore up some small rust spots in the short term but for right now she's gonna get pampered.
I have a build thread for my TDI swap. Check it out if you want to daily drive it you can get incredible power and MPG out of a stock alh vs the 22re or 3.slow.
Already working on swapping a TDI into my buddy's truck it's that impressive he went and got a TDI car for the swap the day after he road in my truck lol
https://youtu.be/BpjhzRc0OAA
Granny gets a little Console love
PO had given some fiberglass fabrication a shot...........
but I was willing to spend a few bucks on ebay for a used one. Wrong color but it's an improvement lol.IMG_4005.jpgIMG_4006.jpg
I might have accidentally fixed Granny's warm start issue. I don't have her registered so she doesn't get to play other than a quick drive down the road for a mile or two every couple of months. So the battery cables were getting corroded, and I took them all apart to clean. I decided to replace a wire and connections (battery -neg terminal to body ground) that looked suspect, and that is the only thing I can figure that fixed the warm start issue. She has restarted warm now on several different occasions. I hope that was it.
Trucks look great!
Whats the deal with the warm start issue? Sometimes thats the signs of a dying fuel pump.
Trucks look great!
Hey Caleb, just now seeing this post. I thought it might be a problem. The tank was new when I bought it a couple years ago, but it does not guarantee the pump is good. The crazy thing is I can pull the afm connector and it will start.
YouTube
Granny gets some love
Well the old girl has been neglected for the last 2+ years and she was cranky.
She still has the warm start issue, but the 22RE runs good once she gets rollin.
I charged the AC the other day and so far she is holding freon, but the idle up circuit will need help. Ordered a new VSV and we'll go from there.
I torqued the Pace setter header that the PO had put on her, but she had a broken stud and was still leaking out the flange and ticking away.
So I pulled the header and the dumb asses put a new gasket over the old gasket, as well as not fixing the broken stud. SMH always fixing other people's BS.
I managed to get the broken stud out, and I had an old stud from when I put headers on my V8 T4R, and it's the same size thread. It's the one on the bottom.
Wondering if I should powder coat the header or save some money and just put some High heat paint on it.
Engine bay is gonna get a bath here soon as well.
Have you thought about having the header ceramic coated? Since it’s already off, it would help with the heat.
That's why I mentioned it, I knew someone would give me some ideas. I hadn't considered the ceramic, but detailing all the rust and painting will take quite a bit of time, and powder coating probably isn't the best solution. Any idea what ceramic will cost? I'm sure geography factors into pricing a little.
Jhunt
