Moog springs?
There's no specs there to be able to evaluate them.
Hopefully someone that actually has them will respond.
I searched online for the OME springs you recommended but I couldn't find just the springs...only the entire kit which I don't want to spend the $ on just yet. Any idea where I can find them?
Thanks! One more question...should I replace the shocks as well? Or am I ok with the stocks til I go for a full lift?
If you get springs that lift the truck over stock height you'll need longer shocks.
If you get springs that return the truck to stock height the stock shocks will work (unless they are bad too).
