07-29-2010, 12:12 AM
Speedometer Problem
I have a 95 3.0 4x4 auto 4runner, and every time im in either 4 low or 4 hi and reverse the little plastic speed sensor gear in the transfer case pops out. This only happens if i reverse if i go forward it doesnt happen, im just getting tired of having to keep snaping that little gear back into the speedo cable. Does anyone know whats going on?
1995 4runner 3.0L, 2.5" leveling kit 31X11.5X15R Yokahama AT/S, 4x4 Conversion Sold (2011)
2007 Tacoma Sport A/C 4X4 6" Fabtech, 6" Acan Leaf springs, SPC UCAs, Dirt Logic Coilovers/ Resi, 35" Goodyear Dura Tracs, TJM plate bumper, Satoshi Grill and other crap. Sold (2015)
2015 4Runner TE 5100s @ 2.5 and .75" spacer in front, Icon 2" coils/ 5160s in rear, Camburg UCAs, Leather seat conversion and more to come
07-30-2010, 08:35 AM
Sounds like the symptom of a failed cable?
Mine bounces at speeds over 35, totally screwing up the cruise control.
Charlie
1995 4Runner. 3.0
07-31-2010, 01:07 AM
There is an assembly that the gear and shaft attaches to along with the cable at the other end, then it goes into the transfer case...
Is the whole assembly coming out of the transfer case?
Do you have to pull out the assembly to replace the gear?
Pics?
I have done a lot of work with my speedo gear and cable... I may be able to help if I understood the problem better...
1986 4Runner Deluxe, 5SPD, R.I.P. @ 182k Miles, July, 2001 - November, 2004.
1987 4Runner SR5, 5SPD, 236k. July 2007-Present
07-31-2010, 10:33 PM
yeah i keep having to pull the assembly and snap the gear back in its really annoying
08-01-2010, 04:47 PM
The gear should be permanently mounted to the shaft, and there is a clip that holds the shaft inside the assembly. You can buy the whole thing from the dealership for about $25. I'd replace the whole unit.
08-01-2010, 08:18 PM
ok yeah i saw it the clip is gone thats why the shaft keeps sliding out, Thanks
08-05-2010, 08:16 PM
Any idea what is causing mine to bounce?
I remember back in the day when a speedo had a cable from the transmission that ran up into the dash and right into the speedometer. Bouncing needle meant the cable was starting to go. I think I put 3 on my '77 olds cutlass.
Charlie
1995 4Runner. 3.0
08-05-2010, 09:19 PM
Bouncing is either that the cable needs lubrication (spin it and run some sewing machine oil down it), or that the driven gear is wearing out.
Lube that cable first.
