Old 04-27-2011, 05:11 PM #1
toYOta22 toYOta22 is offline
toYOta22 is on a distinguished road
Check Engine Light Issue
1995 4Runner V6 3.0
Just had the engine rebuilt at 151,000 miles. The issue is that the engine runs like a beast for the first 15 minutes or so. Then when the check engine light kicks on, the power decreases dramatically (hills that I could normally drive 75 over, I am now doing 55 over). The computer says that issue could be an engine knock, but there isn't one. So my question is: can the check engine light have an effect on how the vehicle runs? If so, should I just disconnect the wires?
Feel free to ask for more information if you need it.
Thanks, Eric
toYOta22 is offline   Reply With QuoteReply With Quote
Old 04-27-2011, 05:20 PM #2
turboSR5's Avatar
turboSR5 turboSR5 is offline
Real Name: Todd
turboSR5 is on a distinguished road
turboSR5's Avatar
Real Name: Todd
I would be that it is either a bad knock sensor or faulty wiring to the sensor. If the ECU thinks there is a knock/ping it will re**** the timing to prevent pre detonation. This results in some pretty bad performance.\
EDIT: Disabling the check engine light will not fix any problems.
1986 4runner 22RTE Turbo SR5 - R.I.P.
1986 Extra-Cab Pickup DLX - Sold
1987 4runner 22re SR5
1984 2wd Exrta Cab
1982 BJ60
turboSR5 is offline   Reply With QuoteReply With Quote
Old 04-27-2011, 05:37 PM #3
Thank you alot.
Eric
Old 05-01-2011, 12:44 AM #4
Yoter95's Avatar
Yoter95 Yoter95 is offline
Yoter95 is on a distinguished road
Yoter95's Avatar
I've got the exact same problem man... they've already gon through and replaced the knock sensor, wires, and even the ecu... still trips the light and i lose a bunch of power. dumped soo much effin money into this i shouldn't have this prob. feel for ya breh. i'll post again if i figure it out
Yoter95 is offline   Reply With QuoteReply With Quote
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 20 07-09-2024 07:28 PM
Check Engine Light, VSC OFF And Check VSC Lights just came on??? the_josh Maintenance/Detailing 5 07-15-2019 01:25 PM
check engine light, high idle, light shaking?? lindseymarie General Discussions 4 03-08-2011 12:13 AM
NC Inspection: check engine light/engine too lean footracer 3rd gen T4Rs 5 09-10-2009 06:39 PM
Just washed engine bay- now check engine light appears BlackIceWAP 3rd gen T4Rs 9 07-09-2006 08:48 PM
