Check Engine Light Issue
toYOta22
1995 4Runner V6 3.0
Just had the engine rebuilt at 151,000 miles. The issue is that the engine runs like a beast for the first 15 minutes or so. Then when the check engine light kicks on, the power decreases dramatically (hills that I could normally drive 75 over, I am now doing 55 over). The computer says that issue could be an engine knock, but there isn't one. So my question is: can the check engine light have an effect on how the vehicle runs? If so, should I just disconnect the wires?
Feel free to ask for more information if you need it.
Thanks, Eric
I would be that it is either a bad knock sensor or faulty wiring to the sensor. If the ECU thinks there is a knock/ping it will re**** the timing to prevent pre detonation. This results in some pretty bad performance.\
EDIT: Disabling the check engine light will not fix any problems.
I've got the exact same problem man... they've already gon through and replaced the knock sensor, wires, and even the ecu... still trips the light and i lose a bunch of power. dumped soo much effin money into this i shouldn't have this prob. feel for ya breh. i'll post again if i figure it out
