Old 09-11-2012, 02:06 PM #1
JWaldz's Avatar
JWaldz JWaldz is offline
Moderator
Real Name: Waldo
JWaldz is a jewel in the rough JWaldz is a jewel in the rough JWaldz is a jewel in the rough
Moderator
JWaldz's Avatar
Real Name: Waldo
Dyna Bead for balancing?
Anybody use them in their tires. I'm interested in trying them out. My 35's can use all the help they can get!
'99 Toyota 4Runner LTD - Dual Locked | Geared | Mid-Travel | 35s | Armored
Sponsors: Coastal OR | Extreme LED | SherpaEC | Overland GG
3G Build: ShowGirl | Instagram: ^Click Above^ | FB Page: JWaldz4R | T4R Mod: Contact Me
JWaldz is offline   Reply With QuoteReply With Quote
Old 09-12-2012, 04:07 PM #2
quicksilvr's Avatar
quicksilvr quicksilvr is offline
quicksilvr is on a distinguished road
quicksilvr's Avatar
I was going to try them, but never did. That said, I think I will try them with my next set of tires, whether they are 285's or just 265's.
2001 SR5~Thundercloud Metallic~3.4L Auto~4x4~260k miles~TRD 2gen black Supercharger~URD AFR Calibrator~B&M 70264~Bilstein Adjustable w/ tall '99 fronts~ProComp 3" rear springs~Nitto Ridge Grappler 285/70R17's on 17x9 Enduro's~Yakima RailRider w/48" bars~ScanGauge II
quicksilvr is offline   Reply With QuoteReply With Quote
Old 09-13-2012, 11:37 AM #3
JWaldz's Avatar
Moderator
Real Name: Waldo
Moderator
JWaldz's Avatar
Real Name: Waldo
Well, Firestone took 3 trips to get it right with balancing and now there are weights galore all over the rim, mostly static weights on the inside. I'm just gonna ditch everything and use dyna beads. Wish me luck lol.
Old 09-15-2012, 04:04 PM #4
chayos00's Avatar
chayos00 chayos00 is offline
chayos00 is on a distinguished road
chayos00's Avatar
Would these beads affect anything with a TPS system?
2008 SR5 4x4 V6 Salsa Red Pearl w/Taupe Interior
Mods: OW 2.0", LR UCA's, 285/70R17 Cooper STT Pro's w/Spidertrax 1.25" Spacer, DirtyDeeds Muffler, SpeedoHealer
Audio: Eclipse HU CD8445, Polk Audio db6501 6.5" Components, Polk Audio db351 3.5" in factory tweeter location, 2 Audiobahn 10" Subs @ 1200W
"I'm an AMERICAN by birth and a VETERAN by choice"
chayos00 is offline   Reply With QuoteReply With Quote
Old 10-08-2012, 05:11 PM #5
crazydubman's Avatar
crazydubman crazydubman is offline
crazydubman is on a distinguished road
I have been looking at the same thing. What I have seen though is you can use air soft pellets and get the same result. May want to look into that route first if you can get the tire to unseat on the bead enough to make it work. would be way cheaper than 20 a pop for the dynabeads.
My beadlocks will be getting them as there is no way im gonna try to balance 100lbs of rubber and expect them to stay balanced with static weights.
Todd:
1997 4runner limited - crawling/camping
http://www.toyota-4runner.org/3rd-ge...ner-build.html
crazydubman is offline   Reply With QuoteReply With Quote
Old 10-08-2012, 07:49 PM #6
SV_Dude SV_Dude is offline
Moderator
Real Name: Jonathan
SV_Dude will become famous soon enough
Moderator
Real Name: Jonathan
Some people say that beads work for balancing and others do not. I tried it once and did not like the results. I used airsoft pellets and used a certain weight based on a chart that I found. My setup was 35" mickey thompson baja claws on 15x10 aluminum wheels. The beads did okay for driving around in a straight line but as soon as I hit a bump or went around a turn, all the beads would go nuts. Going around a turn at 45mph on a light weight lifted vehicle with all 4 tires suddenly losing their balance is scary to say the least. Now that was my worst case scenario. Most of the time the tires would be fine except for hitting the occasional bump in the road and it would wobble for a bit until the beads balanced the wheels again. Then there was an issue with all the beads making a bunch of noise at slow speeds... that was annoying. Overall, I wasn't happy with the beads and I took them out and used the lead weights. Every 6 months or so I'll have to re-balance my wheels. I do my own tire work so that's an easy 30 minute job for me.
ARKRWLR: Please post back with your results. I am really curious how it worked out for you.
SV_Dude is offline   Reply With QuoteReply With Quote
Old 01-10-2013, 11:48 AM #7
Figured I would bring this thread back.
Any luck on the dynabeads yet?
Hoping to get the beadlocks mounted in the next few months and would be interested to see how you like them so far.
Todd:
Old 01-10-2013, 11:55 AM #8
Victor_inox's Avatar
Victor_inox Victor_inox is offline
Victor_inox is on a distinguished road
Enyone knowing basic physics will tell you that dynabeads can't work even theoretically. Otherwise every tire shop will be promoting them and Toyota selling them as an option.
TPMS is another concern, idea of a bunch of weighs moving around freely and hitting that sensor is questionable.
Victor_inox is offline   Reply With QuoteReply With Quote
Old 01-10-2013, 12:27 PM #9
Who said anything about them being for a 4th or 5th gen
The 3rd gens don't have TPMS.
I have talked to a lot of people running them and are very happy with them. Most wheel on a very regular basis.
With larger tires it gets harder and harder to keep them balanced for extended periods of time. Pending if they are Bias or Radial, if the weather is hot or cold, etc. When you air down a lot for wheeling, Your tire will slip a little on the wheel every time you do. This causes those static weights to be shifted slightly from where they need to be everytime you air down.
I have had this happen a lot in the past where a tire shop rebalanced my tires only to shift over the weight on the wheel about an inch.
A dynamic balance would allow the normal effects of constant aired down wheelin to not affect the balance of the tire because it is a "fluid" balancing, meaning it can change location regardless of the relation of wheel to tire.
Also when tire gets chunked up from rocks this will change your balance needed. If you wheel a lot of sharp rocks, (Arizona for example) you will see how brutal they can be on tires and that can mean perfect balance on the way to the trail and death wobble on the way home.
Toyota doesn't use them because for what the average consumer uses their vehicle for, its not as needed. Plus tire shops don't want to mess with spilling beads all over the place everytime they have to change a tire.
My beadlocks can be mounted in my garage so I will be the only one to have my hands on them. If I never had to go to a tire shop again I would be thrilled. I have rarely left a tire shop without a shimmy in the steering wheel from unbalanced tires.
Todd:
Old 01-10-2013, 12:30 PM #10
the TPS system probably wouldn't like the bead hitting the sensors on a regular basis.
Unless you no longer have the sensors, I wouldn't consider bead balancing.
Todd:
Old 01-10-2013, 12:32 PM #11
JWaldz's Avatar
Moderator
Real Name: Waldo
Moderator
JWaldz's Avatar
Real Name: Waldo
I never did get some but I will be looking into getting some air soft bb's this month some time. They're a lot cheaper than the dyna beads. I have a local buddy running air soft bb's in his 35s and bead locks and he says they work great.
Here are his posts on them.
www.toyota-4runner.org/1242881-post53.html
www.toyota-4runner.org/1243845-post55.html
Old 01-10-2013, 12:43 PM #12
Good to know. Ya when talking to the guys at the local offroad shop, they all said to just use air soft pellets. One runs them on his audi A8 and had great luck with them on that as well.
Todd:
Old 01-10-2013, 12:49 PM #13
JWaldz's Avatar
Moderator
Real Name: Waldo
Moderator
JWaldz's Avatar
Real Name: Waldo
Grant it you won't be able to pour them in from the stem but the dyna beads for oversized tires are too big to go in that way anyways. Just make sure there is no moisture on the inside of the tire. The plastic bb's can stick to the moisture especially when cold. That's why you pay more for dyna beads because they're ceramic and have no chance of sticking no matter what condition on the inside of the tire.
Old 01-10-2013, 01:05 PM #14
oh for sure. I would drop them in when mounting the tire on the wheel. I hadn't thought about the moisture. Airsoft BB's should be large enough not to worry too much about that though right?
Todd:
Old 01-13-2013, 06:55 PM #15
chayos00's Avatar
chayos00's Avatar
That was my thinking also.
HTML code is Off
To Bead Lock or Not Dad's Toy 5th gen T4Rs 19 04-29-2021 02:18 PM
Dyna Beads in Tires? ultimatt 3rd gen T4Rs 26 04-16-2016 06:28 PM
Torqueing Dyna trax Desert Fox General Discussions 2 12-23-2011 07:55 PM
Bead locks TopRunner Off-Roading 4 07-31-2008 08:45 PM
Can someone please explain Bead Lock to me? Cleric 4th Gen T4Rs 2 05-11-2005 08:50 PM
