I haven't forgot about updating, just haven't had any time. This project should have taken a weekend. But with the wife and kids it just drags on forever.
I put a total of 6 layers down. The thing has no flex in it whatsoever so I think it's good enough.
After the last layer was dry I put it back in the 4Runner so I could mark where to trim it. I decided not to use the bottom portion cause it just didn't work out so I just cut it off.
The mounting tab that I added in may not work as planned. After I get the rest of it finished I'll see how well it will work. My concern is that the cargo cover may not lock into place with how thick the tab is. I may just use a peice of thin guage steel and secure it to the back of the box with some screws.
After marking my trim lines I pulled it back out and used my Dremmel to trim it. After about half of the trimming was done my Dremmel got so hot it started burning my hands. So I switched over to my 3" air powered cut-off wheel and went to town.
That made short work of the rest of it. I then used my angle grinder (With flap sanding disks) to make the mounting tab a little thinner.
I was planning out the rest of the box (I think the rest will be MDF) and then ran out of time. Hopefully I'll have it completed this weekend.
Last layer drying:
Re-installed:
Marked for trimming:
Trimmed and re-installed:
Waiting for some MDF:
