Old 10-26-2006, 03:14 PM #1
oua oua is offline
oua is an unknown quantity at this point
oua oua is offline
Where to Buy - Factory Amplifier Output Harness
In the past I have always bought the cheapest audio option avalable so I can swap out that OEM junk and put in my own aftermarket stuff.
However the sport edition came with the JBL premium (yeal right - sounds like crap) audio direct from the factory. A ~850 add on. To make light of this extra 850 and to make use of the JBL premium system until I get around to installing a full aftermarket system.
For now I would like to patch up this JBL setup a little bit. I want to add "bass blocker" to door speakers.
What I want to do is open up the rear passenger quarter panel and get access to the factory amplifier.
Here is the question. Where can I buy a EZ quick connect extension harness for the factory amplifier speaker output so I don't have to splice any factory wirings. The quick connect should have one end being male and one end being female. I will spice/cut/add the bass blocker only on the quick connect harness.
Once I decide to go all out on a complete aftermarket system - I want to be able to simply remove the quick connect with all the bass blocker and return the factory JBL system back to it's original state.
oua is offline   Reply With QuoteReply With Quote
Old 11-02-2006, 08:55 PM #2
crozhawk's Avatar
crozhawk crozhawk is offline
crozhawk is on a distinguished road
crozhawk's Avatar
I doubt if you'll find one I looked for a couple weeks...I replaced the entire system (minus the Factory Nav h/u) and i had to use line converters on the factory amp outputs to interface with my aftermarket amps. It's a pain but it's the only way , atleast that I've found that will enable you to have use of the centerchannel and fader controls. I'm currently running just over 1200w RMS and it's clear as a bell. I used 2 line-out converters from Scosche that I picked up for about $20 each and they work perfectly. good luck, let me know if you find a quick connect.
06 Limited 4x4 V8 NAV
Solid Axle Conversion
crozhawk is offline   Reply With QuoteReply With Quote
Old 11-03-2006, 12:26 PM #3
oua oua is offline
oua oua is offline
I am all about SQ. I will never ever ever convert speaker lever output to RCA. That is a No No.
FYI - old fashion DIY procedure to test the noise level of you system. Play a CD. pause it. Then crank up the volume to almost MAX. You will begin hear all the background static/noise that the music once covered.
Anyway - No Luck finding an EZ adapter to buy.
Only way is to get the parts from another 4R with JBL system.
I can tear/unsolider the female adapter from the factory amp and I can cut the male adapter from the factory wire. Of course possibley out of another totaled 4R.
'05 4runner Sport Edition v8 4x4 - SOLD
Old 11-05-2006, 11:43 AM #4
crozhawk's Avatar
crozhawk's Avatar
Well I have the factory Nav, so regardless, I would only have one right and one left output (preamplifier). As for the sound quality in mine ...crystal!!
HTML code is Off
Original Headlights lamp gives less output? JuanSJO 3rd gen T4Rs 1 04-17-2007 01:18 PM
Question on relay with Xenondepot HIDs LV4R 4th Gen T4Rs 6 02-22-2007 04:18 PM
Backup Camera and Factory Navigation wonijack Engines / Suspension / Wheels / Tires / Audio / Accessories 2 03-16-2006 09:51 AM
Trailer Harness - '99 4 Runner -w/ Factory tow pkg maine runner 3rd gen T4Rs 3 02-17-2005 10:28 PM
03 jbl synthesis system sal16 Engines / Suspension / Wheels / Tires / Audio / Accessories 12 12-12-2003 02:34 AM
