09-10-2008, 12:18 PM
Super Moderator
Super Moderator
VSC Off, ATRAC On Mod complete!
I completed the VSC-off mod on my T4R. The cool thing about this mod is the ATRAC is still active.
A great thank-you to Andries at T120. This is his hard work not mine.
What it's like after the mod is complete:
In 2wd dash lights are on (VSC & Diff lock). I didn't mess around enough to decide if VSC is working, traction control IS working; I'm assuming it has full VSC. It has all the familiar noises and accompanying reduction in power. The system seems to get confused if you attempt to change from 2HI to 4HI with the switch on. Lights get stuck in flash mode.
In 4HI it works as advertised You have an unlocked Torsen center diff and no interference from the VSC; the VSC and Diff Lock light are on. You can definitely feel/hear ATRAC doing it's thing. The same deal in 4LO... I can lock and unlock the diff while in 4HI (or 4LO) with my switch on. It locks & unlocks ok. When unlocked the diff lock light continues to flash even after the diff unlocks. It is not a perfect mod. It beats the heck out what Toyota gave from the factory. I am thrilled!
My advice is to not do a mode change with the added VSC switch on (grounding the wire). I may retract/amend that as I learn more. For now I plan to lock and unlock the diff, switch 4HI to 4LO with my added VSC switch in the off (ungrounded or open) position.
The bottom line is it's a great mod that facilitates the use of 4HI and 4LO without VSC interference and the center diff unlocked.
Andries saved me thousands! I was having serious 'VSC-off' envy of the 2008 guys!
This is the original Andries, aka Bulldog, thread: http://www.toyota120.com/forum/showthread.php?t=3817
For further discussion of what the mod will do and why you may or may not want it read here:http://www.toyota-4runner.org/showth...595#post361595
Below are some how-to pics Battery should be disconnected for this procedure! There's a TSB that discusses the risks; basically disconnect the battery. Do not turn or change 4wd mode knob until it's all back together and powered up.
Chris
07 Salsa SR5, 4wd Cyclone pre-cleaner , Aux Transmission Cooler, Hidden Hitch 70779 (600/6000lbs, WDH=730/7300lbs), AirLift 1000, FJCruiser front springs (& now rear too!), Axle Vent Mod, Swaybar Bushing Upgrade, V6 Tick Reduction, VSC off mod, Maplight Mod, 255/75/17 Goodyear Wrangler SAs, Tailpipe Mod
09-10-2008, 12:19 PM
Super Moderator
Super Moderator
The rest of the pics
You can't see it but I put a couple of connectors on the switch wires also so that I can take the dash apart later without pulling and/or cutting wires.
Chris
09-11-2008, 01:19 AM
Super Moderator
Super Moderator
4-wheel power slides now?
Congrats on the mod.
'06 Limited V6
Amy's Mom: "Who's that you're talking to?"
Amy: "It's Uneek, spelled in a 'unique' way."
09-11-2008, 07:46 AM
Super Moderator
Super Moderator
You know it!
Chris
09-23-2008, 12:06 PM
So wait a second---will this work on a 2004? I heard there were some issues with resetting the lights or something like that.
Shaun
2004 Titanium Silver Toyota 4Runner SR5 V6 4WD
265/70-17 LTX M/S, Bilstein 5100's Front (1 3/4" lift), DDM 35W HID 3000K Fogs, Silverstar High Beams, GE Nighthawk Low Beams, Showoff Krypton Hyper White Interior Bulbs, EGR Hood Protector, De-Badged, Husky Floor Liners (F/R), 3M Cabin Filter Mod, Fram SureDrain, Side Exhaust, Scion 1807 H/U
09-28-2008, 09:05 PM
Super Moderator
Super Moderator
Should work fine, I have had no reset issues. Stand-by though, I am going to tweak it and add to this post. I think I can get the lights working right and get it to work in 2wd. If you have the V8 do it as I have posted, no issues.
EDIT: I have had no reset issues thusfar. I have it in for a while now. There's no need to shut the vehicle off or anything other change the switch position.
Chris
10-01-2008, 05:05 PM
I am standing by---This will make for some fun this winter hopefully!
Shaun
10-01-2008, 07:05 PM
Super Moderator
Super Moderator
:awais: I know, me too Friday afternoon or Saturday morning, I'll post the results.
Chris
10-02-2008, 12:22 AM
Super Moderator
Super Moderator
So even if the VSC is deactivated by your switch it shows the center diff is locked when it is not . like in the picture ???
I have a V8 so how would that differ from the v6 as far as what lights up and when.
Why didn't you get a factory VSC off switch from an 08.
< 2016 Classic Silver TE w/KDSS >< Bone stock at the moment >
10-02-2008, 08:06 AM
Super Moderator
Super Moderator
1) That's correct, VSC is defeated and the center diff is UNLOCKED.
2) The procedure was developed for a V8 and the lights work better. The V6 has AAD (ADD?) on the front axle and that requires a couple of extra wires. That's what I need to on Fri or Sat.
3) I might. The factory switch is a momentary and will require the use of a relay (which is fine, in fact better). As wired now I have to shut the switch off when I shut the truck off otherwise on startup the VSC/ATRAC computer can't complete it's self check. By using a momentary switch/relay combo it will return to 'normal' every time you shutdown (like the side airbag defeat button).
Chris
10-02-2008, 10:41 AM
Super Moderator
Super Moderator
I must be misunderstanding . I thought and it looks like the diff lock light is on in the picture.
10-02-2008, 12:36 PM
Super Moderator
Super Moderator
You're correct, the diff lock light and the condition DO NOT agree... The light is on but the diff is NOT locked. The whole deal is to trick the VSC into thinking the center diff IS locked thereby convincing the VSC to take a nap.
When I work on it this weekend I'll let you know if the light indications improve/change.
Chris
10-02-2008, 09:42 PM
Falls...any idea for part numbers for the VSC off switch for an 08. I didn't have that option on my 07. I like my buttons to look clean, like they are supposed to be there in the first place. This mod would be nice if it works on an 07 V8 Ltd Fulltime 4x. I have two free button spaces left on the center console....well actually only one. One is reserved for future off-road lights on a roofrack.
10-02-2008, 10:35 PM
The flyer is a genius.:bowdown:
2007' V6 SE 4WD PIAA 520's.
Yakima Load Warrior
Michelin LTX M/S 265 65 17
Westin Bull Bar Weathertech Mats
Bilsteins 5100's
10-03-2008, 07:42 AM
Super Moderator
Super Moderator
Chris
HTML code is Off
