Originally posted by tarheeltp17
You are fine running the neon off that same power outlet circuit! Most neons come with a 12V plug on them anyway, so you can easily cut that off and wire it into the same circuit. Blowing a fuse is not that big of a deal... fuses blow all the time. They are designed to protect the circuit and the wiring. If the circuit can't handle the load of the neon, then fuse will blow.
Running to the battery is a waste of time for a neon.
Yeah, they do come with 12v plugs but I have to snip them off. I'll wire it all up tonight, then hide the wiring tomorrow. Thanks for the quick responses.
