I've had several people inform me that attempts are being made to sabotage my sale of this truck. By way of anonymous information being stated in regard to it's condition/mechanical state, whatever. So, I can assume who is behind it, I can see you following my posts, I can see you viewing my profile, and I've even had major businesses in the 4runner world personally state usernames being problematic from this board. You know who you are, if you have something PERSONAL to handle, do it with me off the forum and my endeavors, I'll send you my address.
I'm making this public now because messaging a moderator got no response for several days. Well, it apparently needs noted since this kinda shit is allowed on here or "can't be identified".
1999 4runner, manual trans, 4wd, 3.4 engine
220k on body, 122k on engine, 96k on transmission, 400 miles on rear end rebuild (bearings, seals, exciter rings, ect).
AOR front and rear bumpers, Satoshi grill, FN wheels/BFG 33" K02's, OME springs front and rear, Tundra 5100's front and rear, SPC upper arms, SS brake lines, Tundra brake upgrade, weathertech mats, more but I'll elaborate to those fully interested from here.
Maintenance, I have personally put 6k miles on the truck roughly. Majority of this was done within 2k miles, however NOTHING listed has over 5k miles. Receipts available for everything; OEM lower balljoints, OEM inner and outer tie rod ends, Exedy HD clutch, OEM pilot / throw out bearing, MT90 trans fluid, Mobil 1 diff fluids, TIMING BELT/WP service and idlers/tensioner/drive belts/Toyota OEM coolant and parts used for all, OEM rear wheel bearings/seals/abs rings, OEM rear shoes/good drums, ES front sway bar endlinks, Lifetime CV axles up front, Lifetime swaybar endlinks on the rear, OEM TPS/MAF/o2 sensor/plugs/wires/PCV, ES sway bar bushings front and rear, fully sound deadened cab, fully swapped interior, every light bulb/fluid/wear item/maintenance item replaced.
Truck is tight, stops great, looks great, needs nothing. Runs amazing, clutch engages JUST off the floor and grabs hard. No squeaks, wobbles or shimmies at any speed. Never been wheeled by me/clean rust free undercarriage.
Title is clean but it was in a small collision last August, 2015. The truck was declared a total, but due to WA state law, it was too low of a payout to be reported essentially. Clean, clear title in hand, there was a bumper and a door replaced due to accident. I saw before pictures, didn't find this out for myself until fairly recently. Truck was already built, never saw or fixed anything consequently post-wreck so it's just something for your information.
-A/C needs recharged. Entire system is in place, but was disconnected with engine swap and I don't use A/C in this state.
$9500
Olympia, WA area
Stock, day 1
Now
