FS: 1999 4RUNNER 6.0L V8 ENGINE/DRIVETRAIN CONVRSN 1 OWNR GREAT SHAPE $13k obo, in FL
tbsb9595
1999 Toyota 4 runner 2wd SR5 with 400HP 6.0L Vortec engine conversion,
Original Owner, 167K miles on Odometer, but everything that moves has
been replaced and/or upgraded within the last 5k-10K miles. Mild Crane Cam,
Beefed up valve train, rebuilt 4L80E Transmission with new 2200 stall
billet converter and stage 2 shift kit. Extra Engine oil cooler with
fan. Custom radiator, Extra Tranny cooler with fan. 3.5 inch single
Stainless exhaust system with modified ZL1 Ex manifolds. Completely
rebuilt rear with True Trac Posi and 4:11 heavy duty gears. New High
output fuel pump. New custom stronger drive shaft, All New A/C system,
New Windshield (other one was cracked from a rock), 5 Added Autometer
gauges for: Oil press, Water temp, Volts, Oil temp, Trans temp, New
Alpine Stereo with separate amp, and JL audio speakers, Viper alarm
system. Factory Sport hood with Scoop. Sunroof, Everything works except
the cruise control. Poly sway bar bushings, New springs, Rear air bags,
Larger Brakes conversion on the front from a Toyota Tundra, New Bilstein
shocks, New 18" X 10" Wheels. All Tires are Almost new with Michelin
265/60/18 on the front, and 285/55/18 on the rear.
Owned since New. Never in an accident. No leaks. Led lights inside and
out. All it really needs is a paint job. Interior is still very close
to like new condition. Sunroof with no leaks and works perfect.
Runs and drives great, I have spent a lot of time and money on this
truck (much more than the price), and I hate to sell it, but I bought a
bigger camper so I need a bigger Truck for towing. My loss is your gain.
Price: $13K Or best offer
Seller: Tom (727) 515-9015
1999 Toyota 4 runner 2wd sr5 with 400HP 6.0L Vortec engine conversion,
been replaced and/or upgraded within the last 5k miles. Mild Crane Cam,
Beefed up valve train, rebuilt 4L80E Transmission with new 2500 stall
rebuilt rear with True trac Posi and 4:11 heavy duty gears. New High
new camper and I need a bigger Truck for towing. My loss is your gain.
Price: $19K Or best offer
Was there space to where you could have ran a front driveshaft for 4wd? do you have under car pictures?
Any reason you went SD and ditched the MAF?
I'm not really sure about the 4WD as I never looked into it.
I didn't use the MAF as a recommendation of the shop that did the conversion.
AndiGarage
