Climbing dunes
Betukya
Hello everyone i´m a 3d Gen 4wd T4R and i looking for some tips u can give me to climb dunes i getting started in that hobbie and now im trying to clim some easy ones but ai would like to climb the hard ones i already bought an air compressor, and some stuff but i need to know how to drive in dunes, wich is the best speed in 4wd mode and also if there is a way to climb specifically so pleas every one i m gonna w8 for ur answers :D:nerd:
air down to about 12-15 psi, get a decent run at it, you have to pin it to win it and stay into it until just before the top or you get stuck. Check for moguls at the bottom of the hill before you just plow up one. Check the top to make sure there's not a razorback to fall off of. Going down, dont use your brakes. Low range and let the gearing work for you. Brakes are a common mistake for riding down dunes. Dismount or strap down gear, dunes mean speed. Your gear will go every which way if you leave it in or unsecure.
