Old 11-12-2014, 01:05 AM #1
OneOleMan OneOleMan is offline
OneOleMan is on a distinguished road
Questions about the 2012 Limited AWD 4X4
Within the past few days I purchased a 2012 AWD 4X4 4Runner Limited and have some questions about towing a 3500# TT and the use of the 4X4 options that only those here would be able to answer. The salesman I worked with didn’t know a thing about the 4Runner - - really - -, so I don’t feel comfortable asking him anything.
First question: When towing should I use the “D” drive mode or the "S" sport mode? My initial thought is to use the “S” mode when towing up hills, (mountain passes), and going down the other side but while on flat terrain the “D” mode would be okay.
Question two: When should I/could I use the “Down Hill Assist” feature? Can it be used only when the transmission is in the “S” mode?
Last question for today: My 4Runner has H4F, H4L and L4L selections for the transfer case, H4F being AWD; both H4L and L4L show the transfer case is locked and my assumption is use H4L and L4L only in sandy, muddy and snow conditions. Would this be correct or am I barking up the wrong tree?
Any help and suggestions will be appreciated so I don’t tear up this new to me 4Runner.
Pat
Life is Good
2012 4Runner Limited
OneOleMan is offline   Reply With QuoteReply With Quote
Old 11-12-2014, 01:23 AM #2
THatfield's Avatar
THatfield THatfield is offline
Real Name: Taylor
THatfield is on a distinguished road
THatfield's Avatar
Real Name: Taylor
I think towing in D should be fine unless it is shifting up and down, i which case i would use S, and select 4th or 3rd gear to keep it from "hunting" for gears. D should be fine for using DAC. Your owner's manual might elaborate more on proper use of DAC though.
You are correct on the Transfer Case operation. L4L is for extreme 4x4 conditions, when you need lower gearing to gain traction or to keep yourself from getting stuck.
In my 4R my visor has a index card that explains transfer case operation and what each mode does. Perhaps read yours over to help familiarize yourself. There is also a thread around here that discusses the 5th Generation 4WD operation. Search for that for a good read as well..
Welcome on board and enjoy your new to you 4Runner!
1999 4Runner SR5 Highlander V6 4WD ELocker
2008 Toyota 4Runner LTD V8 4WD
2000 4Runner SR5 V6 4WD- Sold
"Why do people measure life by the years, and not by how good the years were?"
THatfield is offline   Reply With QuoteReply With Quote
Old 11-12-2014, 10:47 AM #3
Martinjmpr's Avatar
Martinjmpr Martinjmpr is offline
Martinjmpr will become famous soon enough
Martinjmpr's Avatar
Dac...
If the DAC on the 5th gen is like the one on the 4th gen it will only work when you are in low range and 1st gear.
Martin AKA Zapp Branigan - No longer a 4runner owner!
Martinjmpr is offline   Reply With QuoteReply With Quote
Old 11-12-2014, 01:13 PM #4
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
Modern automatics have grade logic (That's what Honda calls it, I can't remember what Toyota calls it, maybe just "with intelligence") that can guess if you are on a hill or towing and hold low gears longer. It will also automatically downshift for you if you press the brake for a second or so on a long downhill. I assume the 5th gen still does this, and it's not perfect, but it's a good start if you don't want to/need to shift it manually with sport mode. Be sure to downshift on long downhills if it doesn't do it automatically to save your brakes. The computer won't let you over-rev the engine, so go as low as you need to.
The center differential should always be unlocked on dry pavement. Locked is better for low traction situations, and the low range is good for getting unstuck or very slowly crawling over rocks or obstacles on a trail. DAC is for difficult off-road driving, and it will apply the brakes loudly to keep your speed around 2-4mph.
m85476585 is offline   Reply With QuoteReply With Quote
Just picked up 2012 LE - mod questions flynnstone 5th gen T4Rs 3 12-31-2012 02:21 PM
2012 ltd questions TOMMYTHETECH 5th gen T4Rs 39 08-31-2012 08:08 PM
New 2012 TE and a few questions... smallcandle 5th gen T4Rs 21 08-19-2012 12:52 PM
2005 vs. 2012 - a few questions loughman 5th gen T4Rs 9 01-30-2012 04:52 PM
Questions about ordering a 2012 thebwlife 5th gen T4Rs 19 12-07-2011 07:11 PM
