Old 01-17-2019, 09:54 AM #1
Shuba Shuba is offline
Shuba is on a distinguished road
E85!!!!
I accidentally filled my 2017 up with E85 Gasoline ...the check engine ...No Trac light came on and the Cruise Control is not working???? advice please!!
Shuba is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 02:47 PM #2
pDubs's Avatar
pDubs pDubs is offline
pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light pDubs is a glorious beacon of light
pDubs's Avatar
Certainly better than filling with diesel. You will probably get some misfires and feel like crap, but it should be okay.
If you can't siphon it out or drain your fuel tank, I would drive it a ton and top off with regular gas as much as possible.
2014 SR5P
5100s w/Dobinsons 302/505 springs - SCS F5s - 285/70 Wildpeak AT3W - Prinsu Full Length Rack - Smittybilt Gen 2 RTT - Full RCI skids - RSG sliders - Pedal Commander - Gobi ladder - Rago brackets and 32" LED light bar- TSO TRD Pro grille - 5k HIDs - ARB diff breather - other small stuff
pDubs is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 03:14 PM #3
thennen's Avatar
thennen thennen is offline
thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold thennen is a splendid one to behold
thennen's Avatar
What he said ^^^ Keep topping off frequently.
thennen is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 03:24 PM #4
Thanks....I will do that!.. so everything happening is being affected by this? even the cruise control?
Old 01-17-2019, 03:38 PM #5
pDubs's Avatar
pDubs's Avatar
More than likely the check engine is from misfiring or a fuel sensor or something. The Traction control light is most likely disabled simply because there's a CEL.
The cruise control not working is happening only because either one of those is on currently. Domino effect! Should all self resolve. My guess is if you go and get the code read and cleared it will all be fine.
2014 SR5P
Old 01-17-2019, 03:39 PM #6
WeakSauz WeakSauz is offline
WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about WeakSauz has a spectacular aura about
Once you've run the e85 out, I'd recommend a fuel system cleaner/additive
2000 SR5 4x4 | Geared, Locked and Fully restored OEM+ build.
Forged and Cammed 1UZ Single Turbo, Standalone ECU + Built R150 in process. Why, you ask? Because it makes no sense in this platform, and I love it!
WeakSauz is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 03:43 PM #7
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Disconnect the return fuel line and divert it into a bucket. If you can distinguish it from the supply line, and if its easy to disconnect somewhere I don't know.
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 03:43 PM #8
4runnin4mylife's Avatar
4runnin4mylife 4runnin4mylife is offline
4runnin4mylife has a spectacular aura about 4runnin4mylife has a spectacular aura about
1.Drain to half tank of E85
2 Fill up rest of tank with 93 octane
3.Head to dragstrip
'21 MGM Limited Nightshade | 1" Cornfed Leveling Kit | BFG KO2 265/60/20's | PrecisionLED 6000k LED Interior Upgrade
SOLD: '16 Silver TE w/ KDSS | C4 Fab Lo-Pro Bumper | Smittybilt X2O 10k Winch | ARB Dual Compressor w/ Tank | sPOD | XD Philips 4300K HID Upgrade | XD 6000K LED Interior Upgrade | SCS Ray10 Matte Black Wheels | BFG KO2 285/70/17's | Icon 3"/2" Stage 2 Lift | JBA UCA's
4runnin4mylife is offline   Reply With QuoteReply With Quote
Old 01-17-2019, 03:47 PM #9
thennen's Avatar
thennen's Avatar
My 2001 lost VSC and TRAC because of an evap code. It's designed that way. The E85 may be messing with your O2 sensors because it burns differently, and the truck may be turning off traction control in response. I imagine cruise is also tied in to that system, but not sure.
Old 01-17-2019, 04:03 PM #10
Thanks for the great quick replies! appreciated !
Old 01-18-2019, 01:29 AM #11
Bayou_Pro's Avatar
Bayou_Pro Bayou_Pro is offline
Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light Bayou_Pro is a glorious beacon of light
Bayou_Pro's Avatar
Yes definitely so. I'd drain it or pump it out myself. You will run lean with E-85. That's why you are getting the missfires most likely.
Paul
2016 TRD Pro, Mag Gray. Mods: SSO Sliders, Bilstein 6112 Front Springs, Dobinson 599 Rear Springs, GY Duratrac LT285/70R17s, Spidertrax 1.25" Spacers, Morimoto LEDs (Lows, Highs & xB Fogs), Full LED Interior Lights....More to Come
Bayou_Pro is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 02:40 AM #12
LandCruiser's Avatar
LandCruiser LandCruiser is offline
Real Name: Sparky
LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of LandCruiser has much to be proud of
Real Name: Sparky
On a related note, my dad was filling up with E15 for some reason the two months he was up here.
I didn't notice anything wrong with it...
I just asked him WTF and he mistook that it's labeled "86" for being a tier above the 85 trash gas.
Old and (c)rusty.
LandCruiser is offline   Reply With QuoteReply With Quote
Old 01-18-2019, 03:24 AM #13
YellowSnow YellowSnow is offline
Banned
YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough YellowSnow is a jewel in the rough
Banned
Ok OP....is this really your wife posting?
YellowSnow is offline   Reply With QuoteReply With Quote
Old 02-08-2019, 10:53 PM #14
MGTrail MGTrail is offline
MGTrail is on a distinguished road
3.Head to dragstrip
HAHA this is what i used to do with my BMWs running JB4 to achieve an e40-e50 mix.
MGTrail is offline   Reply With QuoteReply With Quote
advice , control , e85 , light , working
