Old 01-01-2022, 12:32 AM #16
Asylvester Asylvester is offline
Asylvester is on a distinguished road
Definitely Get it Treated
I live in NH and rust will rot out the frame real quick if untreated. While used car shopping, I looked at countless cars that were so rusty underneath, I would walk away. When we got our 2009 4runner, the first thing I did was to spray fluid film inside and out on the frame and everywhere else underneath. I got 12 cans of fluid film and an attachment with a small hose with a 360 degree nozzle at the end to get inside the frame. PB Blaster has recently come out with a similar product called surface shield. Home Depot has it and it is slightly cheaper than fluid film. It claims to last 2 years so I use it on the exterior of the frame. I'm very impressed with both products and use them religiously because I HATE rust.
Asylvester is offline   Reply With QuoteReply With Quote
Old 01-02-2022, 12:36 PM #17
ANoob ANoob is offline
ANoob is on a distinguished road
Originally Posted by Blackwatch View Post
Yes, you must undercoat it. I test drove a 1 year old 4Runner this summer that had lots of rust on the frame and hitch. I’m going to try wool wax this time.
Rust will eat a 4Runner quickly.
Same problem as with the Tacomas?
ANoob is offline   Reply With QuoteReply With Quote
Old 01-02-2022, 12:51 PM #18
JustTroItIn's Avatar
JustTroItIn JustTroItIn is offline
JustTroItIn is on a distinguished road
I picked up the Woolwax brand gun and 5 gallon bucket of fluid film. Did all three of my vehicles this year using up about 2.5 gallons total for all three, one being a large E350 van and the other two 3rd gen 4Runners. It's been about 2 months since application and so far happy with the results.
2000 Limited w/ rear locker
-Dobinsons IMS, JBA UCA, Whiteline Bushings
2000 SR5 4WD Auto w/ J Shift
-Stock Beater
JustTroItIn is offline   Reply With QuoteReply With Quote
Old 01-02-2022, 06:51 PM #19
88rnr 88rnr is offline
88rnr is on a distinguished road
New Jersey reply here:
My son has a 2002 Tacoma double cab that still had a decent amount of Noxudol 300 on it from the Toyota voluntary recall. We simply washed and reapplied over the entire frame. Not wanting to apply a different product over the top of it. We used Noxudol 700 cavity wax inside of the frame rails as well.
When my 04 tacoma got a new frame, I chose to treat it using the cavity wax (above) on the inside of the rails and this product RP342: Cosmoline Vehicle Undercoatings - Long Lasting Rust Protection for Vehicles everywhere else on the frame and underside of the body.
So far each is holding up ok, occasional touch-ups as needed. As was suggested in comment above. A self healing product is best.
88rnr is offline   Reply With QuoteReply With Quote
Old 01-11-2022, 08:30 PM #20
Plain Old Mike's Avatar
Plain Old Mike Plain Old Mike is offline
Plain Old Mike is on a distinguished road
Yeah, New York 4runner owner here too. The roads today looked like a forest fire was up ahead there was so much salt dust flying around. Not good for any car….
Plain Old Mike is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 07:17 PM #21
Blackwatch's Avatar
Blackwatch Blackwatch is offline
Blackwatch has a spectacular aura about Blackwatch has a spectacular aura about
Blackwatch's Avatar
Anyone have any experience with Waxoyl? Sounds pretty good
Blackwatch is offline   Reply With QuoteReply With Quote
Old 01-13-2022, 08:25 PM #22
zameul40's Avatar
zameul40 zameul40 is offline
zameul40 is on a distinguished road
zameul40's Avatar
Fluid film
I am sold on Fluid Film for undercoating. I hate the sealers that basically just lock moisture around the steel of the frame and cause more problems than doing nothing. I think i used about half a gallon on my runner but thats completly spraying the interior of the boxed frame and splooging the entire undercarriage.
zameul40 is offline   Reply With QuoteReply With Quote
Old 01-14-2022, 12:23 AM #23
jbtvt's Avatar
jbtvt jbtvt is offline
jbtvt has a spectacular aura about jbtvt has a spectacular aura about
jbtvt's Avatar
DIY writeup here Ultimate oil undercoating guide (DIY Waxoyl)
Downside as mentioned is that it softens on the areas that get warm, mostly on shock valves and brake fittings in my case, which basically reduces it to the efficacy of your typical room temp applied fluid film/etc. In a bad new England winter those need to be applied twice a season. In most areas this waxoyl lasts for about 5 years. My frame and everything above is still covered but a few areas are getting crusty and could use a touch up so in the spring I'll be hosing it down and respraying. I may try cosmoline on the fittings and driveshaft.
Anything that goes on at room temperature and doesn't contain solvents taht evaporate out will wash off at room temperature in 1/2 - 2 seasons depending on your area.
'85 4Runner, 22re 5spd; '90 4Runner, 5spd, 3.4 swap
'98 GS400 1uz; '07 GX470 2uz
jbtvt is offline   Reply With QuoteReply With Quote
Old 01-14-2022, 02:24 AM #24
whyzee125 whyzee125 is offline
whyzee125 is on a distinguished road
Cosmoline is a good product that doesn't get enough recognition.
IMO, an oil-based, creeping/self-healing is the best by far.
Fluid film, krown, wd-40, or even used ATF are all superb. In a sprayer and properly applied, you can keep any truck pretty much rust free with not too much time invested by treating your undercarriage with one of these. Personally I like fluid film because I think it's a bit better for the environment than ATF or wd-40. Krown is probably similar but haven't used it.
That being said, any treatment is more environmentally friendly than scrapping your car due to rust and the idea is that the majority of it sticks to your frame anyway.
Originally Posted by LittleCaesar View Post
At 5'7", I'd need a rocket up the wazoo to get in it.
But it looks good. I can't wait to see it being driven.
whyzee125 is offline   Reply With QuoteReply With Quote
Old 01-14-2022, 07:32 AM #25
Too Stroked's Avatar
Too Stroked Too Stroked is offline
Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough Too Stroked is a jewel in the rough
After not so good experiences with several other products (Ziebart, cough, cough) and lots of research, I went with Waxoyl. I like what I read and what I see now that it's applied. Does it work? Give me a few years to see.
Too Stroked is offline   Reply With QuoteReply With Quote
Old 01-14-2022, 12:18 PM #26
Blackwatch's Avatar
Blackwatch's Avatar
I was considering wool wax, from what I've read it's the same as fluid film but doesn't wash off as easy. The wool wax dealer says full application 2 years in a row then touch ups for the rest of the years.
The Waxoyl dealer said one application then annual reapplications in wear spots. Waxoyl adds some sound deadening as well.
Not sure which is better.
Old 01-19-2022, 10:26 AM #27
damstr damstr is offline
damstr is on a distinguished road
Once temps start warming up here I will be using Corroseal as the rust converter followed by a protective layer of Rustoleum then protected with RP-342 Cosmoline.
damstr is offline   Reply With QuoteReply With Quote
city’s , iowa , lot , state , undercoating
Undercoating VulgarWizard So Cal 4 01-29-2024 02:11 PM
undercoating orcking 5th gen T4Rs 6 10-01-2020 04:40 PM
Undercoating on your T4R Joe_2004SE_NY Maintenance/Detailing 18 05-12-2020 10:28 PM
undercoating dirtrider9x 3rd gen T4Rs 14 03-04-2013 09:39 AM
Undercoating Dylan Classic T4Rs 6 03-26-2011 12:14 PM
