Tax Refund Skid Plate Group Buy - 3rd gen
isu2014
Ryno All Terrain Products is back! I am offering a group discount on my skid plates for 3rd gen 4Runners and 1st gen Tacomas. I will run this group buy until April 30th. A $250 deposit is due by April 30th. The rest can be paid when the order is ready to ship. Choice of 1/8" or 3/16" thick for light weight or extra strength.
Here is everything I am offering:
3 PIECE SET $415: Included in purchase are IFS, transmission, transfer case skids, and all necessary hardware to install. Drilling is required.
Weights:
1/8" = 87 pounds
3/16" = 123 pounds
RACK COVERAGE SKID $235: Included in purchase is an extended IFS skid plate that covers the steering rack and all necessary hardware to install to factory mounting location.
Weights:
1/8" = 42 pounds
3/16" = 60 pounds
TACOMA FUEL TANK SKID $235: Included in purchase is fuel tank skid made for xtra and double cabs, and all necessary hardware to install. Drilling is required.
1/8" = 32 pounds
3/16" = 45 pounds
Details:
3/16" or 1/8" steel
40-60 pounds per piece
Uses factory mounting holes are used except on transfer case skid
Cutout for engine oil drain plug included
Replaces both factory skid plates
Works with front differential drops - no spacers needed
Not painted or powdered
Manufacturing time is 2-3 weeks from when I order. I will ship when the order is complete.
Shipping will be fedex ground. Pay by paypal, cash, or check.
PM for shipping quotes...
For rough shipping cost estimates on a 3 piece set:
Colorado: $85
California: $100
Massachusetts: $100
Florida: $100
Texas: $85
Kentucky: $85
Email me at [email protected] if you don't have an account here but want skids.
3 PIECE SET
I made a couple minor beneficial updates to the current skids, but the fit is all the same.
RACK COVERAGE SKID
4ajuzuve.jpg~original
uqa9eve2.jpg~original
a3e4uba8.jpg~original
Previous sale threads with more info and whatnot:
RAT Products Skid Plates - 1st gen Tacoma, 3rd gen T4R - Tacoma World Forums
Skid plates from RAT Products - 1st gen - Tacoma World Forums
3 piece skid installation instructions:
RAT Products Skid Plate Install Write up - Tacoma World Forums
List:
1. S20004runner - 3 piece - 1/8"
2. Reelamin - ifs & trans - 1/8"
3. zumogo - 3 piece - 3/16"
4. gmv4k - rack coverage - 1/8"
5. Helokid1 - 3 piece - 3/16"
Is it possible to just order the transmission and transfer case skids? Colors purple and lime green (from the picture above) for a 99 taco v6 ext cab
I got on one his of first group buys on T4R and can't say enough about the quality of them. A little over a year and they're holding up just like they should!
I considered stainless, but the yield strength is only about 2/3 what steel is, so it would dent and deform easier. And the cost is almost double. I wouldn't want them for the price.
Well that's good to know.
So what grade steel you using on this batch? Cold rolled?
More questions come to mind:
Curious on what minor changes/improvements you made?
Holes need to be drilled through the frame or plates, or both?
Can the truck be jacked up from the 1/8" skids without deformation?
If purchasing skids with the tank skid, will the shipping price be much different? Cheaper if multiple orders go to one location, I'm guessing?
I will be using 1018 CR. As for changes, I made the mounting flanges larger on the t-case skid, as well as added a flange to the back side of both wings for extra strength against flexing. I made the oil drain hole round instead of a larger slot. The frame will need drilled to mount the t-case skid.
I jacked on my 3/16" with no issue, so 1/8" should be ok. It will probably flex a little but not give out.
The gas tank skid will not fit a 4runner. It is for a Tacoma. I run this same sale on other forums so it is there for others.
If I can use fastenal to ship multiple orders to one location, it will be cheaper.
Part 2 & 3
Bought the front skid from you last year and am also interested in the other 2 skids. I'm sure shipping to IL won't be bad for them either.
Should all 3 bolt right up? Or do you have to drill some holes?
Edit: Sorry read the op.
Did you shorten the length of the transfer case skid? Does is still extend beyond the body of the catalytic converter?
seltzernator
