Transmission Flushing on 99 4Runner
skinshag
I have a 99 4Runner, V6, Automatic, 85K. The SUV is in mint condition however the transmission has never been serviced. The fluid is fairly clear and still red.
I am getting conflicting information from the Toyota service reps. Some say to flush, others not.
Has anyone flushed a transmission on a 99 4Runner?
Is this an accepted practice? What are the risk and precautions I should take.
Any feedback, advice and suggestions are appreciated.
Thanks
I recommend flushing all the fluid out of the transmission.
The best way to do a transmission flush yourself is to:
1. Remove the tranny pan drain plug, and allow fluid to drain from pan (approx 3-4 quarts should drain out).
Note: Steps 2 and 3 are not necessary, but I highly recommend doing them.
2. Consider removing the pan while it's drained to clean the filter screen and the magnets at the bottom of the pan. (This will add an hour or two to the job.) Careful if you remove the filter. More fluid will fall out of it when you loosen the bolts that hold it in.
3. Re-install tranny pan (I use a gasket maker called "the right stuff" made by permatex. It works well, and you don't have to wait a long time for it to cure before you can re-fill your transmission after you put the pan back on.)
4. Re-install tranny pan drain plug, and refill tranny pan (through dipstick tube) with ATF. Put in the same amount that you drained from the pan in step 1. Use the dipstick to verify that you have the correct level in the pan.
5. After having drained and refilled the tranny pan , you can then flush the rest of the fluid out by disconnecting the ATF cooling line coming from the stock tranny cooler in the radiator, then, start the truck and let the tranny pump spit out approximately 1 quart of fluid.
6. Shut off the truck, and top up the tranny fluid through the dipstick tube. Repeat this 11-12 times or so (depending on the capacity of your transmission), to flush the majority of your fluid, with very little waste.
7. Reconnect ATF cooling line to tranny cooler.
8. Run truck for a few minutes, then check fluid level. Top up if necessary.
