Old 03-06-2010, 11:49 AM #61
Redstone8 Redstone8 is offline
Redstone8 is an unknown quantity at this point
My 05 4Runner has about 41,000 miles on it and I am going to replace all the pads. The rotors still look like I can get some more usage out of them so I am on the fence about replacing those too. I called the dealership since I intend to go with the Toyota OEM pads and the guy I spoke to was telling me I might need pins which run about $4/each and some type of other kit which cost about $30. Now I have been doing my own brakes on my cars over the past 20 years, but this is the first time I will be doing it on the 4Runner. I only anticipated buying the pads and shims and maybe the rotors if needed once I do a closer inspection, but not all this other stuff this guy is telling me about.
Has anyone ever had to replace anything additional in a routine brake job on the 4runner other than the pads, shims and rotors provided that nothing is broken. I have not taken anything apart yet, but plan to do so sometime this weekend so I just wanted to get some feedback from the other members so see what your experience has been. Thanks in advance for any input/comments.
Redstone8 is offline   Reply With QuoteReply With Quote
Old 03-06-2010, 11:53 AM #62
MikesToy MikesToy is offline
Banned
MikesToy is on a distinguished road
Banned
Run your fingers thru the rotors. If there are any rough spots (uneven) then get them re-surfaced.
MikesToy is offline   Reply With QuoteReply With Quote
Old 03-06-2010, 11:27 PM #63
kimboy kimboy is offline
kimboy is on a distinguished road
Torque the bolts and lugs to spec to ensure everything comes together.
kimboy is offline   Reply With QuoteReply With Quote
Old 03-07-2010, 11:19 AM #64
TechWrench's Avatar
TechWrench TechWrench is offline
TechWrench will become famous soon enough
TechWrench's Avatar
The pins the dealership are trying to sell are the retaining pins for the front pads (two per caliper), which have a bad tendency to get badly rusted. This can make them very difficult to remove. In some cases, you will have to sand/grind the excess rust scale build up from the pins before they can be driven out of the caliper, so you can remove the pads. I don't know what the other $30 dollar kit is, might be a spring kit. In any case, you might, or might not need it. It depends on what you find when you acutally start to take things apart.
I can Explain it to you, I can't Understand it for you.
'08 Tundra SR5 5.7 V8 Double Cab, White, Equalizer WD system, '91 Coachmen Catalina 260FK, '89 Grumman GSS w/35HP Force O/B, 8' Snowbear utility trailer, 2012 Polaris 500HO LE in Camo, 7 x 14 TWF Landscape trailer w/2 ramps.
TechWrench is offline   Reply With QuoteReply With Quote
Old 08-29-2010, 07:28 AM #65
ronsta's Avatar
ronsta ronsta is offline
ronsta is on a distinguished road
ronsta's Avatar
Front & rear pads (OEM) changed at 52000k miles, no squealing yet, had about 20% left but a friend explained to me that if you wait till the indicators tell you to change the pads then your rotors are slowly being dug into by the indicator clips which is no good. Same friend who helped me do the maintenance told me the shims were still good so now I have front & rear shims sitting around.
2007 V6 SE 4WD Shadow Mica
Weathertech window deflectors, floor & cargo mats; 3M Clear Bra, front (wouldn't do again), Purolator PureOne 20195
RATEK 8000k HID low & fog, Gentex 453 Auto Dim HomeLink AMBER Compass Mirror; Rubber: 265/70/17 Yokohama Geolandar A/T-S installed 1/14/11, Denso IKH20 spark plugs (6) installed at 60k miles; HCF delete
ronsta is offline   Reply With QuoteReply With Quote
Old 09-02-2010, 08:55 AM #66
Ducman's Avatar
Ducman Ducman is offline
Ducman is on a distinguished road
Ducman's Avatar
Make sure you take a good look at the backside of the rotors before you decide to re-use them. Run your finger across the inside outer edge.
The pins you FOR SURE want to replace and be sure to use some brake lube on them. Not sure what the $30 kit would be unless its shims though or something.
05 SR5 V8 4WD | Cracked Exhaust Manifolds| Magnaflow Catback | Bilstein 5100s | Kenwood DNX5120 Nav | Rear DVD | OEM 06+ LED Tails | Heated Leather | A/T Revos
Ducman is offline   Reply With QuoteReply With Quote
Old 09-02-2010, 04:36 PM #67
bokmeipai bokmeipai is offline
bokmeipai is on a distinguished road
Front pads & rotors replaced at 18k miles. I just bought the car from someone who rarely drove it. It had the steering wheel shake when stepping on brake, don't know why this happened at such low miles but mechanic checked out all the other components and said they were fine.
bokmeipai is offline   Reply With QuoteReply With Quote
Old 09-03-2010, 01:06 PM #68
pmdata pmdata is offline
pmdata is an unknown quantity at this point
Can someone provide a step by step walkthrough link for replacing the front pads on a forth gen? This will be my first brake work, and I want to make sure I have a good go-by.
Thanks in advance.
2007 SR5 4Runner V6 4X4 - Nautical Blue
pmdata is offline   Reply With QuoteReply With Quote
Old 09-03-2010, 01:36 PM #69
Ducman's Avatar
Ducman's Avatar
Thanks in advance.
I think I may be able to find one for ya...
http://www.toyota-4runner.org/mainte...lkthrough.html
Old 09-03-2010, 03:58 PM #70
Awesome. Thanks. I read this one a few weeks ago and thought it was more rotor centric.
I'll give it a shot.
Cheers.
Old 09-03-2010, 04:08 PM #71
Ducman's Avatar
Ducman's Avatar
Easy
Cheers.
Same deal pretty much, you won't need a hammer though
Again I would strongly suggest a careful examination of the back of the rotors before you decide you are going to re-use them.
Take a few minutes sometime BEFORE the night you decide to do the pads and put it up on stands, pull the tire with the wheel turned and get under there with a flashlight and check the inner face of the rotor before you decide you are going to reuse them.
My 2 cents is you are gonna be in there anyway already and the stock rotors are nothing special. Treat her right and get some Napa Ultra Premiums.
Old 09-04-2010, 10:17 AM #72
You convinced me. I ordered a set of ceramic pads and centric rotors. Looking forward to the install...
Projects ordered:
Brakes - Hawk ceramic pads/Centric rotors
Bilstein 5100 adjustable shocks
Bushing replacements
Thanks again for all the help.
Brake Assist...what is it?? Thai 4th Gen T4Rs 3 02-01-2022 03:24 PM
Front brake caliper & pad replacement Kmvreter Maintenance/Detailing 121 04-21-2017 10:55 PM
Dynamic Rear Proportioning (aka EBD) Thai 4th Gen T4Rs 1 06-20-2011 09:24 PM
TRD brake pad install yournamehere 4th Gen T4Rs 0 09-18-2008 09:59 PM
Disc & Drum Brakes Thai Maintenance/Detailing 0 11-20-2002 04:32 PM
