Old 04-25-2011, 05:28 PM #16
truckmike26 truckmike26 is offline
truckmike26 is on a distinguished road
That's what the 2x4 chunk prevented. There's a circular impression in it now.
'94 Pickup Xtra-Cab V6/Auto 4WD
'09 4Runner SR5 V6 4WD
'21 Tacoma TRD Off-Road
truckmike26 is offline   Reply With QuoteReply With Quote
Old 11-09-2017, 02:22 PM #17
chopper1 chopper1 is offline
chopper1 is on a distinguished road
Jacking 03 4runner
I have a 2-post floor lift. It fits fine on the frame of my 03 4runner but won't reach back to the rear axle. Can anyone tell me if, when raised from the frame, will the rear axle sag down far enough to damage anything (hoses/wires). If I can't find out from someone who's done it, I'll use chains to support the rear axle and keep it from hanging too low, but it's an inconvenience. Thanks for any advice.
Bill in Oregon
chopper1 is offline   Reply With QuoteReply With Quote
Old 11-09-2017, 02:23 PM #18
jacking 03 4runner
By the way. The 03 4runner I want to raise up with my 2-post lift is totally stock
Bill
Old 11-10-2017, 02:01 PM #19
Muzzle of Bees Muzzle of Bees is offline
Muzzle of Bees will become famous soon enough
I had a hard time locating the place for my factory jack to work initially as well. It is odd, but there is an indented place on one of the crossing braces where the jack tip fits nicely. That is for the front wheels. That worked. I also looked at the manual before hand too. That helped just enough. The manual is not really clear though.
2016 TEP
Muzzle of Bees is offline   Reply With QuoteReply With Quote
Old 11-18-2017, 01:07 PM #20
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
Bill in Oregon
It's fine. I do it all the time. The shocks limit the axle droop, as designed. No wires or hoses will be damaged. If you bring your 4runner into any Toyota dealer for undercar service, the first thing they'll do is lift it by the frame with a 2/4 post lift just as you want to do. Same at most tire shops. The manual specifies the fore and aft side rails as lift points, and says nothing about supporting the axles, because it's unnecessary.
Keep in mind also that those of us who offroad extend the rear axles to full droop routinely. The 4runner wouldn't be much of an offroad vehicle if the brake lines got damaged every time that happened.
Now, if you want to change your rear shocks, you need to be a bit more careful. Once the shocks are disconnected, the axle can droop far enough to stretch the brake lines.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
One cause & fix for "VSC TRAC" & "VSC OFF" lights, Zero Point Calibration MicaBlue03 Problems & Warranty Issues 300 06-19-2024 06:30 PM
Yaw Rate and Acceleration Sensor Zero Point Calibration iDRiVaT4R 5th gen T4Rs 100 10-09-2022 08:15 PM
Tire jacking points Only4Gold General Discussions 5 09-28-2011 10:13 PM
Zero point didnt work how to turn off "VSC TRAC" & "VSC OFF" & "ABS" lights sciff5 4th Gen T4Rs 6 09-27-2010 12:10 AM
