Old 09-24-2011, 03:19 PM #46
SUBTEGRAL SUBTEGRAL is offline
Banned
SUBTEGRAL is on a distinguished road
Banned
How often do you rotate your tires?
I watch them and rotate them as needed.
Rear-wheel drive, so the tires on the rear-end wear down faster.
I usually rotate front to back around every six months or so.
But last time I noticed that both my passenger side tires were worn down a little more than the driver side tires, so I switched the front driver side tire with the rear passenger side tire (only rotated these two tires) so that the two tires with the most tread are both back with the drive axle and the two tires with the lowest tread are both back on the front axle.
SUBTEGRAL is offline   Reply With QuoteReply With Quote
Old 03-08-2020, 02:01 PM #47
810moto's Avatar
810moto 810moto is offline
810moto is on a distinguished road
810moto's Avatar
Threw on a set of Nitto Grapplers, never rotated them and got just under 8 years out of them. Score!
2004 SR5 2WD,285/75 Nittos,RB-1.5"BL,K&N drop in,LED interior Ltg,12v mod,Debadge,Daystar lights,Optronics rear lights,FJ swap,Fog Light mod, All-Weather mats,ES swaybar bushings & end links,Spidertraxx,HCF delete,1/2" toytec spacer,2custom cargoboxes
810moto is offline   Reply With QuoteReply With Quote
Old 03-10-2020, 06:59 AM #48
HarveyLewis HarveyLewis is offline
HarveyLewis is on a distinguished road
Rotate every 8-9K usually. I know most do it at 5K, but I honestly never had issues with my tactic either.
HarveyLewis is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 02:10 PM #49
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
This topic has so many answers because of different driving styles. Someone who does 95% highway has a way different wear situation than someone in the city/suburbs with lots of stop start off ramps etc.
I usually go by the outside edge of the front tires. They get feathered edges - one side of the tread block higher than the other - which you can feel by running your hand in both directions.
Over the years and different locations where I've lived (and different vehicle weights) my rotation has varied from about 4,000 miles all the way up to 12,000.
Looking at my tires now with about 8,500 miles on the oil, I will probably just rotate when I do my oil change in a couple of months.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 03:17 PM #50
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I rotate the tires every oil change.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 03-12-2020, 09:16 PM #51
How often do you change your oil?
Between outfits.
Old 03-16-2020, 05:59 PM #52
xyzzy xyzzy is offline
xyzzy will become famous soon enough
I rotate every time I swap in/out the winter tire and wheel set with the summer tire and wheel set and work hard to wear each of them out every 4-5 years. I remember where a tire came from by sticking a piece of duct tape in the center cap with the labels "from DF" "from DR" "from PF" "from PR" and "from SP" then when these tires come out of storage, I do my swap and replace the center cap into the correct location.
In general, you *can* take a winter directional rotation tire like the Blizzak and run it opposite the indicated direction. Doing so will only make it wear a slight bit more rapidly, so remember that in a pinch if you have to.
Running something like a summer ultra high performance directional tire the opposite way will suffer significantly more from a performance perspective.
The easiest way to determine which tires will or won't suffer too much from running in the opposite direction is to take a look at the tread, if it's asymmetric (look at both left-right and front-back symmetry), performance will suffer more than a symmetric tread will.
YMMV, that's why I stated "in general".
xyzzy is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 02:50 PM #53
Dillusion Dillusion is offline
Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light Dillusion is a glorious beacon of light
Every oil change which is once a year and less than 3k miles.
Probably over kill but oh well.
2018 TRD OFF ROAD
My Build
Dillusion is offline   Reply With QuoteReply With Quote
Old 03-24-2020, 09:57 PM #54
Better more often than not often enough!!
Between outfits.
Old 03-24-2020, 10:17 PM #55
sam18142 sam18142 is offline
sam18142 is on a distinguished road
Thumbs up
Every 5000 miles at my local Toyota dealer
sam18142 is offline   Reply With QuoteReply With Quote
Dunlop GrandTrek AT20 265/70/R17 Tires BRAND NEW set of 4 doodman Classifieds - buy & sell (no commercial ads please) 3 03-22-2010 10:20 PM
New Tires, '08. Kwik8608 Engines / Suspension / Wheels / Tires / Audio / Accessories 22 02-18-2010 07:17 PM
Time to change tires...yippee Hayn4R Off-Roading 13 12-18-2008 04:47 PM
Winter Tires Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-20-2002 04:57 PM
Michelin tops in tires again: J.D. Power Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 0 11-18-2002 05:05 PM
