01-15-2011, 02:43 AM
#106
If your vehicle doesn't have a second breather under the hood then the breathers for the tranny/xfer are under the shift boot (on top of the tranny). They are pretty high is my point.
The metal ones on the rear axle have a check valve and yes you could potentially suck water past the two seals at each rear wheel. The plastic breathers with the hose fitting just have the dust cap and no check valve.
Extended Axle breathers
08-07-2011, 08:21 PM
#107
Originally Posted by Thai
Something else to think about...at least in the 4th gen 4runners, there are 1 to 2 breather tubes in the engine bay, on the driver's side of the engine block. If you have a V6, then you should have 2 breather tubes (with silver caps). If you have a V8, then you should have only one. The transmission and transfer case do NOT have breather extension. They have breather caps just like the rear axle. So, Toyota only extended the front differential...the other stuff is for your weekend projects!
Here is some good info on the FJ forums: SCUBA Driver Transmission, Transfer Case, Rear Differential & E-Locker Breather MOD - Toyota FJ Cruiser Forum
I would highly recommend the above mod(s) if you go off-roading a lot or do mudding/river crossings.
Thai:
In looking at that FJ forum, there are 6 breathers to consider: 1) the front diff, 2) the front actuator, 3) the rear diff, 4) the tranny, 5) the transfer case, and 6) the E-locker.
I have an '08 4th gen V6, so I was able to locate two breathers in the engine bay up by the battery. I assume these two are the front diff and front actuator, correct?
I was also easily able to locate the low hanging rear diff one, which I intend on moving up soon here. This leaves three breathers.
I managed to locate another one behind the engine just on top of the tranny, which I'll assume is the tranny. Does the 4runner have a transfer case breather as well? Is it just tucked up closer to the engine? And lastly, do the 4th gens have E-lockers and consequently a breather on that as well? I know I have a center diff lock, so shouldn't it be down there somewhere?
2008 V6 4WD Sport Edition 4Runner
3"/2" Toytech Spacer lift
1" Toytech Body Lift
Spidertrax 1.25" wheel spacers
285/70-17 Goodyear Duratracs
10-13-2011, 04:19 PM
#108
Just an FYI: I installed a rear diff breather in my '07 FJC, running it inside the jack compartment like Doozi....be aware that when the rear diff heats up (like climbing in the mountains, or towing), you will get the gear oil odor in the passenger compartment. I used a small Spectre cone-type breather filter from AutoZone at the terminus, as was done by a number of other FJC owners.
'06 V8 Limited 4x4
Toytec 3" ULK/Bilstein 5100's, BFG 285/70R17 KO2's on FJC wheels, Total Chaos UCA's & lower link skids, BudBuilt full skids, AllPro 1.25" wheel adapters, BAMuffler, Pioneer AVIC-X920BT, Kenwood TM-V71A, Cobra 75WXST, TruControl Silver brake controller, all LED replacement bulbs, Demello 3-hoop front bumper, ACRO & PIAA lights, Custom Demello sliders, Wilco Hitchgate Solo, '11 Rockwood Roo 21SS Hybrid Travel Trailer
TLCA# 19763
10-13-2011, 07:00 PM
#109
You do get some gear oil odor in the passenger compartment on longer drives. I noticed it on a 2200-mile road trip to the Midwest. Obviously, we ran into some humid conditions so I had the "Recirc" button on with the AC and noticed the smell... turning the "Recirc" off to pull in outside air almost immediately got rid of the smell. Aside from that trip, I've never noticed it.
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
08-27-2012, 08:25 PM
#110
Noise
I just completed the breather yesterday and anyone in Chicago knows that the 4" of rain we got made some massive puddles, so I had to "test" the breather out. Well, my install may have failed the test. Driving around town I can hear a faint hum. (think of a five year old mmmmmmmmm). Here is what I think it might be:
1. Driving through puddles at speed ruined the new front bearings
2. Water has gotten through my connection at the diff. (cap is at the gas filler neck) However, I dropped the spare and checked but the hose was still tight and not rubbing any spinning thing. So does water in the diff oil make any noise?
3. The extended volume of the diff that I created just naturally reverberates noise. I really hope this is the case.
Thanks!
11-16-2012, 04:18 PM
#111
Thanks!
Hey did you ever get this resolved?
2003 Sport Edition 4.7L V8 4WD, weather tech, carbon Filter delete, POR-15, Deeza Heavy Duty End-links, Prothane Bushings, AMSoil tranny, AMSoil diffs, Mobile 1 Synthetic, stay tuned more to come!
11-25-2012, 10:57 PM
#112
lol no. I'm not worried about it though. It's nothing major, because nothing has broken. And its not the bearings, because it doesn't go away when turning. It hasn't gotten worse (still really quiet), so I just let the radio make it disappear
11-04-2013, 07:46 PM
#113
Originally Posted by Good Times
I'd like to say that I've successfully done the rear diff breather mod on the new 4th gen 4runner. The existing parts worked as I expected.
Expected time: 1 hr or so including trying to take pix.
Tools required:
13mm and 14mm Box/Open wrenches
Screwdriver
Wire Cutter
hot water
Image of the stock rear diff (looks the same like any toyota!)
Use a 14mm wrench to remove the stock breather. Before removing the breather completely make sure to clean around the breather so you don't get anything side.
Should look like this when you remove the breather..
Add the union into the differential housing. Should tighten down but will have a thread or two shown. (Use 13mm wrench)
Attach the hose. Make sure you have enough slack so when the diff is at it's lowest point you still have enough hose for it to move.
Run the hose along any route to a higher point in the vehicle. I chose to run it into the gas cap area which is pretty darn high. If the water goes that high I'm already in trouble anyway!
Dip the other end of the hose in hot water to let the rubber hose expand. Then insert the new breather and clamp it down. Find a place to secure it and you're done!
30 min sounds about right... just takes abit longer when you try and take some pix... esp taking gloves off so your camera doesn't get dirty
well i did think about using wd-40 but i just didn't want any unkonwn fluids to get inside the hose. figure if i used hot water, the water will evaporate whereas the wd-40 will stay on the hose for a long time... hence might mix w/ the oil inside... so i figure ehe hot water should do the trick
actually the 3/8" was fine for me. dunno but hey if it works, it works!
1> the entire length of my hose was about 5 ft and 2 inches or so... i think if you have 18" of space hose you're okay... (don't rem exactly but i did read somewhere that if you have about 5-6ft of hose from the diff to the gas cap then you're fine...
2> i put the breather to the 8 o'clock area. i made a hole about 1/2 the size of the hose and just forced it in there. i purposely left alot of slack in the gas cap area because i didn't want the breather to get stuck on the wall of the gas cap. that breather has to be able to move (i.e. spring inside to let air out) so make sure it's free to move around. (hence the question 1... have extra )..
3> yeah the hissing was normal... nothing to be worried about
thanks for the good info!
11-28-2013, 11:35 AM
#114
Real Name: Andre Campos
cool informative video
just one more thing on the to do list, before I take out my t4r
95' runner sr5
ES bushings
VAFM enlargement
"get busy living or get busy dieing"
11-28-2013, 04:41 PM
#115
Real Name: Cory
Real Name: Cory
I just run creeper breathers. Never had a problem.
1992 T4R SR5 22re SAR Rig, SAS, 63s, Duals, Twin Sticks, 5.29s, 36" Iroks, 14.5" LED Bar, TJM front Bumper, Marlin Crawler Rear Bumper, Detroit Locked, Trail Gear sliders, Cobra 29gtl CB, Yaesu FT-8800R VHF/UHF, Icom f521, Rola Roof Basket, LCE header w/ Flowmaster 44, LED Rock Lights, Smittybilt 9500k winch.
10-02-2016, 01:03 PM
#116
Real Name: Scramble
Real Name: Scramble
Bump for three reasons:
1- A thread from 2002 is rare to pull up in a search
2- I'm doing this mod today
3- Remember when Thai was into 4Runners
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
10-02-2016, 02:09 PM
#117
Real Name: Just call me the Grease Monkey
Thanks for this, I just replaced my plugged up breather but didn't extend it. I'll do this.
Also I read that the breather increases power or something, why would pressure buildup with a clogged breather reduce power?
10-14-2016, 08:50 PM
#118
Real Name: Lon
Real Name: Lon
Only if it has the "R"....read bottom part here
4Runners.org - Type R Rear Differential
All men dream: but not equally. Those who dream by night in the dusty recesses of their minds wake in the day to find that it was vanity: but the dreamers of the day are dangerous men, for they may act their dreams with open eyes, to make it possible.
T. E. Lawrence
01-25-2017, 01:56 PM
#119
Real Name: Miguel
Real Name: Miguel
So I found this video about relocating the rear diff and e-locker using the ARB kit: https://www.youtube.com/watch?v=FGelulaLo90 and was wondering if the guy couldn't have just used the ARB breather manifold to also connect the e-locker line like he did with the rear diff line? (fast forward to minute 12:20). In the vid it looks like he relocates the e-locker line using the oem breather next to the ARB breather manifold...
IG: trail.edition
01-25-2017, 02:28 PM
#120
Real Name: Will
Real Name: Will
Yeah, the ARB manifold has four connections. Both of my lines are connected to it.
Liquidmantis's modest [boring] build thread
2016 MGM TEP w/KDSS | OME BP-51 w/ 2889 rear | SSO Bumper | Warn Zeon 10-S Plat | TRD Pro wheels | BFG K02 275/70/17 | RCI sliders | RCI alu skids | Gobi Stealth No Rise | 1Up USA hitch rack
