Old 01-21-2016, 02:48 PM #1
4Rager's Avatar
4Rager 4Rager is offline
4Rager is on a distinguished road
4Rager's Avatar
How often do you air down?
I go out on the local trails at least a couple times a month, and I've never once aired down. When I was stock it was partly because the truck came with nitrogen inflated tires that I didn't want to let out (part of the dealer's "Sierra Package" or some BS like that, which I got them to take off the price) and partly because I don't have a compressor to refill the tires.
Most of the trails I frequent are not designated OHV trails, but old mining or power company roads that are no longer maintained. They can get quite rocky at times, but nothing that I couldn't handle with my stock TE. It's also worth mentioning that 95% of the time the trails are bone dry and tractions is not much of an issue.
My question is, when does it become strongly recommended to air down? I understand the advantages of a larger tire footprint and that the tire can conform better to rough surfaces, but I haven't been in a situation where I felt like that was necessary. I guess it would be nice in rock gardens from a comfort standpoint and might reduce wear and tear on the suspension a bit, but it just seems like a hassle.
What conditions/situations do you guys air down and what advantages am I overlooking?
Typical trails:
This is on the rougher end:
2014 Trail Edition Premium w/KDSS - 3" Suspension Lift - FOX 2.5 DSC Coilovers - FOX 2.0 IFP Shocks - OME 3" Springs - LR UCA's - Metaltech Sliders - XD Enduro Pro Wheels - 285/70r17 BFG KO2's - Kenwood 5 Channel Amp w/ JBL speakers and JL 12" W3V3 - K&N intake - HID low beams - TRS LED Fogs
4Rager is offline   Reply With QuoteReply With Quote
Old 01-21-2016, 04:53 PM #2
GHARP57's Avatar
GHARP57 GHARP57 is offline
Real Name: Greg
GHARP57 is on a distinguished road
GHARP57's Avatar
Real Name: Greg
I have terra grapplers that are not LT rated so I air down only to about 25. That gives me better comfort over the really rocky stuff and I can still drive 30 minutes back on pavement to air up. 35lbs on really rocky stuff can bounce you around a lot. i think that is why a lot of people air down is so they aren't beaten to death by being shook up so much
99 Runner-TBU, 265/75/16 Nitto Terragrapplers, Limited running boards taken off. sold
been out the game for a couple years now, i miss my 4runner
GHARP57 is offline   Reply With QuoteReply With Quote
Old 01-21-2016, 04:58 PM #3
4Rager's Avatar
4Rager's Avatar
That makes sense. It does get kind of annoying when it's so rocky all you can do is idle along in 1st gear in 4lo and still get bounced around like crazy. I just figured that comes with the territory.
Old 01-21-2016, 05:04 PM #4
GHARP57's Avatar
Real Name: Greg
GHARP57's Avatar
Real Name: Greg
Yeah I was very cautious the first time i went out wheeling. I had Michelin LTX ms2's on the truck then and I went from 38 to 30 psi because I was so worried about cutting a tire and popping a bead. I have went lower and lower each time, now I am down to the 25 range and may drop down to 22-25 with the snow we will be getting here in Va tomorrow. If you have LT rated tires you can probably drop to 15 lbs and still be safe I see the guys I run with do that all the time, but then they need to air up after we are off the trails.
Old 01-21-2016, 06:21 PM #5
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
for the areas you're running, and anything that would require 4 low, I would be airing down.
I drop tire pressure if just going up for a drive with the family. it just makes for a much more comfortable ride.
I also have a good compressor to air back up at the end of the day. it helps ease any concerns of airing down.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 01-21-2016, 06:34 PM #6
JB.'s Avatar
JB. JB. is offline
JB. will become famous soon enough
JB. JB. is offline
JB.'s Avatar
Have aired down virtually every one of the (many) hundreds of off-pavement forays in the last decade of owning this truck (4th gen). Once it became a habit, I became spoiled.
I'd say the only thing you're missing is the comfort but as you mentioned, the tradeoff is not having to mess with airing down/up. But if you ever come across a hill you can't make you'll be amazed at what airing down will do for you.
There's also the issue of long term suspension life but that's speculation that I have no idea how to quantify.
Btw, I wheeled a lot of the local area in August when I helped my son move there to attend UNR. I really enjoyed it. I'm not a gun guy but I like the gun culture there because I imagine many of the locals expect to be able to use the back roads to go shooting. Anything that keeps the back roads open is good in my book. Slept in my truck a few times out in the sticks. Nothing like waking up to the sound of gunfire. No alarm necessary.
2005 Limited V8
Bilstein 5100 at .85
5th gen SR5 springs
BFG AT KO2 LT265/70/17 Load C (Replaced Revo 2 LT265/70/17 Load E)
Hanna sliders
JB. is offline   Reply With QuoteReply With Quote
Old 01-21-2016, 07:04 PM #7
4Rager's Avatar
4Rager's Avatar
You just touched on one of my favorite things about living up here. There are a few actual "trails" sure, but you can drive to the edge of town in almost any direction and find an un-gated dirt road and just venture off into the sagebrush. A lot of times it doesn't end up being very challenging (which isn't a bad thing considering I'm usually solo), but you get the chance to explore a new trail every trip. I've heard of a local 4x4 club that I want to get involved with to find some more difficult trails where you want to be sure there's other rigs and recovery gear.
Old 01-22-2016, 03:58 AM #8
KidVermicious's Avatar
KidVermicious KidVermicious is offline
Real Name: Kevin
KidVermicious has a spectacular aura about KidVermicious has a spectacular aura about
Real Name: Kevin
I air down for comfort and to save time far more often than because I need the traction. 20-25 PSI does a good job of smoothing the washboard out, and you can traverse sections like the pics you posted much faster with squishy tires. Airing up when you hit pavement might be a hassle, but less hassle than crawling through a patch of baby heads at 5-10 MPH because you can't go any faster.
'My needle always settles between west and southwest. The future lies that way to me, and the earth seems more unexhausted and richer on that side.' - Thoreau, sort of.
The Grey Bastard, 1985 4Runner, driveway ornament.
Utah DesertRunners T4R, for all things wheeling and 4Runner in Utah.
KidVermicious is offline   Reply With QuoteReply With Quote
Old 01-22-2016, 04:47 AM #9
tigger tigger is offline
tigger is on a distinguished road
While not as effective on stockers this vid shows a really good reason to air down.
https://www.youtube.com/watch?v=9Kz8mmLkeks
But honestly, it makes a day of off-roading so much more comfortable.
tigger is offline   Reply With QuoteReply With Quote
Old 01-22-2016, 11:53 AM #10
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
For sand driving I will air down every single time. Usually run 15psi.
For other offroading it depends on the terrain and how long I intend to be out, for example a full day wheeling at Rausch Ck I will drop down to 20 and go lower if I feel it's needed. But if I don't need low range, I probably won't air down.
techno is offline   Reply With QuoteReply With Quote
Old 01-24-2016, 10:27 PM #11
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
I took my 4runner on the beach about a dozen times. I aired down for about half of them. I never noticed any issues either way. The ride was a little smoother when I dropped down to 22psi on P series 265/70/16's.
I took a full size truck onto the beach with straight up street tires and didn't air down at all without any issues.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-30-2016, 01:34 AM #12
Ron4RNevada's Avatar
Ron4RNevada Ron4RNevada is offline
Real Name: Ron
Ron4RNevada is on a distinguished road
Real Name: Ron
I rarely air down:
Airing down for "comfort" doesn't make much sense to me - When driving through rocks at 3 miles an hour airing down doesn't change anything comfort wise. How fast do you guys drive off-road?
Airing down to about 20psig in soft sand helps a tiny bit.
I have never found that airing down in snow or ice ever made any difference.
Back in the old days when I was first off-roading (about 1955) in much less technical vehicles and crappy tires airing down seemed to helps a tiny bit.
I know I'll get flamed by a whole bunch of you young-uns - but I've been doing this a hell of a long time.......
Totally stock 2013 SR5 4WD. Have added Toyo Open Country M/T LT 265/70-R17 (E) tires the first week I owned it. Added second set of Toyo M/Ts at 86900 miles.Added RCI OFF-ROAD Rock Slidersat 84000 miles. Added RCI OFF-ROAD front skid plate at 90,000 miles. Daily driver and so far spending about 30% of time/mileage off-road. Previous truck 2004 Land Rover Discovery that also spent about a third of it's life off-road. I HANG AROUND HERE "THE T4R FASHION FORUM" JUST FOR LAUGHS.
Perfect vehicle as it stands for northern Nevada terrain. Keep it stock - it'll go most anywhere as is.
Ron4RNevada is offline   Reply With QuoteReply With Quote
Old 01-30-2016, 06:31 PM #13
D Farms's Avatar
D Farms D Farms is offline
D Farms is on a distinguished road
D Farms's Avatar
Originally Posted by Ron4RNevada View Post
I rarely air down:
No offense, but it sounds like your idea of offroading is going down a graded fire road. Any time I do a trail I air down for a few reasons. it effectively gives you more wheel travel because the tire acts like a soft spring. the rotation of the tire dampens the cushion of the tire as well. your suspension now shares the load of work with the tire. less vibrations are transmitted to the body and therefore your body. your kidneys will last longer. it gives you more traction because it deforms and grabs rocks more easily and also because of the extra travel you gain at each corner. the lower you go the more these come into play. I personally run 10psi on the trail, but its different for everyone. with stock size p rated tires you probably dont want to go that low, maybe 18 psi.
realistically a stock 4runner is pretty capable, but if you do any real offroading airing down makes the ride much better and makes the trucks job easier.
'02 Toyota 4Runner SR5
E-Locked | Geared | Mid-Travel | 35s | Armored | 100% Chooched
D Farms is offline   Reply With QuoteReply With Quote
Old 01-30-2016, 06:52 PM #14
Real Name: Kevin
Real Name: Kevin
I rarely air down:
With respect, Ron, if I wanna go 3 MPH I'll get out and hike. My truck lets me cover ground so I can see more stuff, and I can cover ground faster if I air down.
That doesn't mean you have to air down - you do whatever floats your boat, and more power to you. But don't come in here playing the old guy card and pretending that because you don't drive on anything more than dirt roads, that the rest of us don't know how to wheel, or that because you're too stubborn to air down that the rest of us shouldn't either.
"Airing down in snow doesn't make a difference", indeed.
Old 01-31-2016, 01:17 PM #15
Real Name: Ron
Real Name: Ron
In answer to the flamers -> In the past 15 years I've done over 300 documented and extensive off-roading treks - mostly in Land Rovers but then in the 4Runner for the past year. Most of the treks from 50 t0 500 miles. Mostly in northern Nevada but also some in northern California, Utah and Arizona. As it's mostly quite dry here I don't have to worry too much about water and mud. Typical trail is sand, small rocks, moderate rocks. Mostly in mountains; mostly old mining and ranch trails.
A few examples:
Hmm - photobucket not cooperating today
