Old 03-14-2007, 11:14 AM #1
gonzo's Avatar
gonzo gonzo is offline
gonzo is an unknown quantity at this point
gonzo's Avatar
where to install an air locker?
i am looking to get an arb locker installed in my runner. anyone know of any shop that would/could do this type of installation in the southeast virginia area?
2004 SE V8 4WD
gonzo is offline   Reply With QuoteReply With Quote
Old 03-14-2007, 11:50 AM #2
ron86toy ron86toy is offline
ron86toy is an unknown quantity at this point
In my opinion DIY.....just to gain knowledge .I have done one at it is not that difficult.There are alot of good how to write-ups on it.
If you want to take it in just call around to ring and pinion shops...plan on spending the at least 500.00 on the install.
Get ahold of local off-road shops for suggestions where to take it.....they may have a shop they deal with regularly or do in house
ron86toy is offline   Reply With QuoteReply With Quote
Old 03-14-2007, 02:34 PM #3
gonzo's Avatar
gonzo's Avatar
i have neither the time nor the confidence to do it myself. large mechanical projects such as this typically go awry in my experience.
i contacted the two largest off-road places around here (the ones that do monster lifts) and asked if they do installs or if they can recommend someone who could and both shops said that aftermarket air lockers are crap and that i am just looking for trouble if i get one installed. needless to say, i did not get a recommendation.
2004 SE V8 4WD
Old 03-14-2007, 02:46 PM #4
I am not sure what you will be running it in.....I personally would not run one either.Have you checked into a factory e-locker?Alot of them are selling complete 3rd's already set up,just need to have electrical done.
I dont run selectable because I am not on the street very often.If I ever do it would be an e-locker or cable(ox locker).The air lines are too easy to damage(heat,cuts).One little cut in the line and you loose your locker since it needs constant pressure to be locked.
BTW I run Detroit lockers f/r
Old 03-15-2007, 10:34 AM #5
fourwd1's Avatar
fourwd1 fourwd1 is online now
Moderator
Real Name: I'm Gumby, damn it
fourwd1 is a glorious beacon of light fourwd1 is a glorious beacon of light fourwd1 is a glorious beacon of light fourwd1 is a glorious beacon of light fourwd1 is a glorious beacon of light
Moderator
fourwd1's Avatar
Check out Iron Pig Offroad.
'89 4Runner SR5 - stock
fourwd1 is online now   Reply With QuoteReply With Quote
Old 03-19-2007, 10:46 AM #6
techno's Avatar
techno techno is offline
techno is a jewel in the rough techno is a jewel in the rough techno is a jewel in the rough
techno's Avatar
Sorry, cant suggest a place to do the install, but I would back you up on a decission to get an airlocker. They are a fantastic locker. Extremely strong and reliable. As far as getting cuts and heat damage to the air line, unless you run the line along your exhaust pipe and drive though a field of razor blades, thats just not going to happen. The only remote chance of damage is getting the line snagged on something like tree branches if you drive over a fallen tree. Most shops will run the air line parallel with your fuel and brake lines since they are positioned to avoid the chance of damage. ARB sells a heavy duty air line kit if you plan on extreme wheeling.
Also, unless you have the right tools (torque wrench, dial indicator, tooth contact dye, bearing pullers, bench press, tap and die set etc) and some automotive mechanical experience, I would not reccomend trying the install yourself.
techno is offline   Reply With QuoteReply With Quote
Old 03-20-2007, 04:52 PM #7
T?@\7 T?@\7 is offline
T?@\7 is on a distinguished road
techno: Man, do you have any pics of your Patrol? Those things are so sick! I had never really heard of them until I went to Panama last summer on a surf trip and there were some really bad ass patrols there! Id like to see it
1987 dlx
SHAKKA
Originally Posted by SCRunner12 View Post
Where's T?@\7 at? He's always talking about bong rips in his posts. I thought he would be all over this post by now.
T?@\7 is offline   Reply With QuoteReply With Quote
Old 03-20-2007, 06:29 PM #8
techno's Avatar
techno's Avatar
This is getting a bit off-topic but here it is...
'77 G60 Patrol, 5.7lt V8 dual fuel, 5 speed, rear air locker, MQ front discs, 33 BFGs, Landcruiser rear leafs with Defender long travel shocks, custom front suspension, 50mm body lift and some other stuff....
where to install an air locker?-vic-range1-jpg
Old 03-20-2007, 10:42 PM #9
Mr. Lambdebois's Avatar
Mr. Lambdebois Mr. Lambdebois is offline
Mr. Lambdebois is an unknown quantity at this point
Pretty cool....
Mr. Lambdebois is offline   Reply With QuoteReply With Quote
Old 03-21-2007, 01:26 AM #10
Originally posted by Mr. Lambdebois
Pretty cool....
INdeed!
And sorry for the offtopic interjections! good luck with the air locker, I cant wait to be looking for an installer myself.
Is there a 4wheel parts near you? Def not the cheapest but prob reliable
1987 dlx
SHAKKA
Old 03-21-2007, 08:43 AM #11
gonzo's Avatar
gonzo's Avatar
fredricksburg isn't too bad, only three hours away.
2004 SE V8 4WD
Old 04-04-2007, 11:42 AM #12
Bala de Plata's Avatar
Bala de Plata Bala de Plata is offline
Bala de Plata is an unknown quantity at this point
I would support you on air locker also. They are in very well built and can be rebuilt if you ever do have a problem. Also on the plastic vs. heavy duty stainless lines. I would say go with the plastic. If you do have a problem with the plastic such as a cut or melt, you can easily cut out the affected piece and patch in a new piece with there patch kit on trail and do as often as needed. On a stainless line, if you have a problem, you cant field repair it.
Also, if you wanna just remove the entire third you can ship it to ZUK's in AZ. http://www.gearinstalls.com/ He is a guru when it comes to totota thirds and lockers/gear. You can ship him your third and he will build to your specs and ship back to you. Just an option.
good luck
05 v8 2wd Pre4runner
Titanium Metallic with Stone
List is too long, wait for the pics......
Bala de Plata is offline   Reply With QuoteReply With Quote
Old 04-04-2007, 11:58 AM #13
fourwd1's Avatar
Moderator
Moderator
fourwd1's Avatar
Lance does real good work, but I think there may be a shop down near the beach. You down that way?
Old 04-05-2007, 08:22 AM #14
gonzo's Avatar
gonzo's Avatar
20 minutes from the beach- what is the place called?
2004 SE V8 4WD
Old 04-05-2007, 10:34 AM #15
mlbgoat's Avatar
mlbgoat mlbgoat is offline
mlbgoat is on a distinguished road
mlbgoat's Avatar
There is Production Off Road, off VA Beach Blvd near Oceana Blvd. I spoke to someone there about a year ago (just inquiring about a lift and locker intall). He told me he had a guy there that worked with gears and lockers. I never pursued it further, but that might be an option for you.
mlbgoat is offline   Reply With QuoteReply With Quote
Air Bag install four Classic T4Rs 1 10-01-2010 11:45 PM
Fresh air vent blowing hot when air is cool outside ougrad1 Problems & Warranty Issues 9 12-19-2009 09:18 AM
Air filter restriction causes sulfur smell?? Fro-Runner Problems & Warranty Issues 17 09-29-2006 09:46 AM
K&N air filters Thai Engines / Suspension / Wheels / Tires / Audio / Accessories 3 10-02-2003 09:26 AM
