Old 09-14-2020, 03:18 PM #16
patkelly4370's Avatar
patkelly4370 patkelly4370 is offline
patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold patkelly4370 is a splendid one to behold
I'm no expert, thus this thread. (which is about shackle orientation, but this is good too)
I've read the loops as recovery vs tie down. I see both trains of thought. For sake of discussion I will refer to factory tie down (TD) or aftermarket recovery point (RP).
The TD, on the front, is a loop welded to a bracket of frame material, welded to the radiator support with a bead front & back of the loop. They are not "rated".
The RP is "rated" and is attached with grade 10.9 bolts, 9¼" apart, to the same spot as the TD & the main frame. It is one piece ½" thick.
As you can see in the first picture I have both TD & RP. I was thinking of using the bow shackle in the RP and a soft shackle through the TD and the loop of the strap as a backup.
I don't do bling. They are a bright color to make them easier to find by anyone during a recovery. Someone with more experience than me may notice the TD and determine that may be a better choice for the particular situation. I left myself with options.
In the rear there is one TD. A loop welded to a .20" thick piece of metal. It has no markings on the bolts.
I have replace it with two one-piece, ½" thick RP, with grade 10.9 bolts. I also have the receiver hitch RP. Again, as many options as possible at this time.
Thanks to everyone for the replies and insight. I'd like to hear more thoughts and experience.
patkelly4370 is offline   Reply With QuoteReply With Quote
Old 09-17-2020, 09:10 AM #17
Ogre75 Ogre75 is offline
Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about Ogre75 has a spectacular aura about
With the design of the rear OEM, vs the aftermarket, i'd use the aftermarket. based on the orientation of it's mounting location. That and the fact that I'd see the OEM bending before the aftermarket.
2014 4R SR5 - 3" Dobinsons, 285/70 Wild Peak AT3, RCI Skid & Sliders, CBI Bumper, Firewire light bar, Diode Dynamics Fogs
Ogre75 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 06:08 PM #18
Originally Posted by WeedKillrr View Post
I don't understand why you "mounted" recovery points other than for a bling factor--which is fine if that's what you're going for. I agree with other replies, use the OEM loops.
Hmm...
"Bling factor". Nearest mall is 100 miles.
Old 09-25-2020, 10:24 AM #19
WeedKillrr's Avatar
WeedKillrr WeedKillrr is offline
WeedKillrr is on a distinguished road
WeedKillrr's Avatar
Dude, most pics and builds on here are about bling--which is fine. Not every goal is to have an Ultra4 racer.
No offense intended.
WeedKillrr is offline   Reply With QuoteReply With Quote
Old 04-11-2021, 01:47 AM #20
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
I’d say the curved part of the shackle goes in the recovery point with the pin holding the end of your strap. You can use a tree saver strap as a bridal to halve the load. Just slide the the tree save through the open end of your recovery strap and connect it to your recovery point with some shackles.
Curious why you didn’t just get a hitch mounted recovery point for the rear?
Also, these are not for bling, as some have stated. Recovery points are usually a bright color, most commonly red, so they’re easy to locate when you’re bogged. The factory tie down points might work, or they might sheer off and seriously injure someone.
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
165 , points , recovery , safest , technique
Want to keep stock bumper, but add recovery points/shackles to the front... muscle_doc 5th gen T4Rs 46 06-21-2021 05:36 PM
5th gen recovery points Dario Off-Roading 2 11-10-2014 09:34 PM
FYI $30 WARN Recovery Straps Clearance TOY2G General Discussions 67 04-07-2014 09:22 PM
Recovery points Ohcrymore Off-Roading 8 01-30-2014 08:51 PM
Are bow shackles really necessary for vehicle recovery? 10majfar Off-Roading 25 05-08-2012 10:04 AM
