Old 10-03-2011, 10:51 PM #1
Daron-t4r's Avatar
Daron-t4r Daron-t4r is offline
Daron-t4r is on a distinguished road
Daron-t4r's Avatar
Winch and Winch Mount
Hey off-roaders. I was mudding this weekend, and after getting stuck, decided a winch would be a good idea (as well as a lift).
So what is your favorite? Im looking for a moderately cheep one. As long as I can pull my 4th gen out of a mud puddle or something like that. It seems like warn winches are the most popular.
Also, since I have a 4th gen, I would like to mount it on a brush guard or a similar product. Again, what do you recommend. I don't want to replace my front bumper (as in the shrockbumper) because it is just too pricy at the moment.
All questions and comment are appreciated.
2005 4WD Limited V6. Pacific Blue Metallic -- "The Fourplayer"
Current Mods: +ToyTec Ultimate Lift w/ Superflex and Bilstein 5100s + Cobra Iphone Radar detector/voltometer + aFe stage 2 CAI w/ pro-dry + URD MAF calibrator
Daron-t4r is offline   Reply With QuoteReply With Quote
Old 10-04-2011, 01:48 AM #2
darkie3495's Avatar
darkie3495 darkie3495 is offline
Moderator
darkie3495 will become famous soon enough
Moderator
darkie3495's Avatar
If you are looking for an winch that provides the most bang for your buck, take a look at smittybilt XRC 8. you can find them online for around $299. Or else keep an eye out on craigslist. Don't forget to pick up a snatch block to double your pulling power.
No brush guard is going to strong enough to carry or use a winch. Take a look at this thread: NEW Hidden Front Receiver Hitch!!!. Then add a removable hitch receiver winch mount and you're all set.
Kevin's 2008 4x4 Build Thread
Perkins Performance | Shrockworks | Demello | BudBuilt | ICON | Warn | Overland Warehouse | Goodyear | Lightforce | Spidertrax | Powertank | Complete LED Conversion
darkie3495 is offline   Reply With QuoteReply With Quote
Old 10-04-2011, 10:04 AM #3
Daron-t4r's Avatar
Daron-t4r's Avatar
is that a synthetic cable, or steel?
Old 10-04-2011, 10:56 AM #4
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
Steel. if you want to step up to synthetic, you'll be in the $450 range.
Old 10-04-2011, 06:07 PM #5
Daron-t4r's Avatar
Daron-t4r's Avatar
ok and last question, is there a cheaper way to mount it?
Old 10-04-2011, 06:27 PM #6
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
Not that i know of. the only other option I know of is to mount a winch behind the stock bumper using a custom winch plate similar to what Harper7 has on his 5th Gen which would actually be more money.
If money is an issue, just save the cash, carry a few tow straps and have your buddies pull you out if you get stuck. As long as you're not alone (which you shouldn't be anyway) there is always a way to get out.
Old 10-04-2011, 06:55 PM #7
Daron-t4r's Avatar
Daron-t4r's Avatar
Yup, just need to decide whether to drop the cash or not.
Thanks for the help.
Old 10-04-2011, 07:30 PM #8
darkie3495's Avatar
Moderator
Moderator
darkie3495's Avatar
No worries. I saw your other thread regarding lifts. You'll go pretty far with a nice lift and good tires.
Old 11-14-2011, 11:31 PM #9
CAN-03runner's Avatar
CAN-03runner CAN-03runner is offline
CAN-03runner is on a distinguished road
If you are pretty much just doing mud puddles, and simply need to be pulled out, and it doesn't really matter if you go forward or backward then a rear hitch receiver winch mount is pretty inexpensive compared to a full front bumper.
This will pull you backwards but it will get you out. And you only need to bring when you go mud "puddling" it's not a full time install.
2003 4Runner Sport 4.7 V8 Silver/Grey - Fr/Rr ARB Locker - OME 885/895 - LR UCA - BFG KM2 255/80/17- RCI Skids - Demello Sliders - Bud Hidden Winch- Runva Winch - Synthetic oils- Trail Stripes - Two Baby Seats...
1984/86 4runner In Progress....... V6 swap - High Steer - 33" MTZ - 4.88 Gears - welded rear - ARB front - axle gaussets - Diff covers - Longfields - 4.7 crawler - Titan Winch http://www.toyota-4runner.org/classi...ner-build.html
CAN-03runner is offline   Reply With QuoteReply With Quote
Old 11-15-2011, 08:06 PM #10
ironhippy ironhippy is offline
ironhippy is on a distinguished road
agreed, using the rear hitch is the only "cheap" way to do it. You won't want to pull hard side to side with it, but it will work.
This guy did a hidden mount which is relatively cheap, provided you can do the work yourself. Rasta 4x4 intermal winch mount in factory bumper - Page 3 - Toyota 120 Platforms Forum
2005 Limited 4wd, 85,000 miles
2002 Tacoma SR5 4wd, 5 spd 123,000 miles
sold 1997 Lexus LX450 - triple locked from the factory 305,000 kms sold
sold 1998 SR5 4wd - 4cyl, 5 spd 205,000 kms sold
sold 2000 SR5, 4wd - V6, auto 190,000 kms sold
ironhippy is offline   Reply With QuoteReply With Quote
Old 11-29-2011, 03:18 AM #11
Daron-t4r's Avatar
Daron-t4r's Avatar
Any you have seen, or that you would recommend?
Old 12-08-2011, 03:07 PM #12
TheTuckerTaxi's Avatar
TheTuckerTaxi TheTuckerTaxi is offline
TheTuckerTaxi is on a distinguished road
I've been toying with the idea of getting a winch and doing something similar to Tradera or the hidden hitch receiver like darkie3495 said. However when I go wheeling I always plan to go with a group on the harder stuff where a recovery strap is normally a better option then a winch and hopefully somone else in your group will have a winch.
You can also use a hi lift as a come-a-long (with the correct accesories) or get an actual come-a-long but neither will be as easy or as powerful as a winch and will be a great workout!
If you plan on doing some serious wheeling, go with a group, it's much safer and there will be more options and equipment to get you unstuck. If you plan to do serious wheeling by yourself then get a winch and a truck full of emergency supplies, and some hiking shoes in case all else fails!
2006 Sport Edition V6 4x4
OME 884 + Superflex | 275/65/18 Goodyear Duratracs | Lightforce UCAs | Midland 75
TheTuckerTaxi is offline   Reply With QuoteReply With Quote
Old 12-08-2011, 11:07 PM #13
Daron-t4r's Avatar
Daron-t4r's Avatar
Yeah, right now I'm looking at a winch to go with a winch bumper, the search continues!
5th Gen winch mount trentfysty 5th gen T4Rs 41 01-21-2019 10:37 AM
4th Gen Lucrum Winch Mount Brock@Lucrum 4th Gen T4Rs 9 05-19-2012 02:21 AM
best way to mount a winch? SaltwatersouL Classic T4Rs 1 07-06-2011 09:50 PM
Winch Mount? nytefog 4th Gen T4Rs 1 05-17-2008 12:55 AM
Winch Mount hre814 Off-Roading 7 05-02-2005 10:05 PM
