I’m pretty sure it’s dead Jim. Rear drivers lower link mount broke off frame.
https://uploads.tapatalk-cdn.com/202...db737f98c3.jpg
This really sucks. Just got it how I want it. I’m sure this is fatal and non repairable Sent from my iPhone using Tapatalk |
Quote:
Frame swap'time.
It's gonna take some fabrication but it's repairable. You'll likely end up having to cut more of the frame out so whoever repairs it has good steel to weld to. If you weld to rusting metal, it'll just fail again. This will also likely result in having to replace the body mount bracket as well, which by the looks of it wouldn't hurt to be replaced. What's the rest of the frame/area look like?
Quote:
That’s my worry. It’s got 281,000 miles on it and this failure was pure stealth. Rusting from the inside out. I’m Leary on how good the rest of it is. Where it broke away from the frame should be clean metal not rust like it’s been cracked for awhile. I need to figure out who to talk to to see if it can be fixed. Sent from my iPhone using Tapatalk |
Any welder worth their salt can fix a basic frame crack - small cracks/splits are NOT the end of the world. Watch any video of someone fixing a barn find and they typically gotta touch up multiple parts of the frame. As said it's gonna need a little metal fab to ensure you have something to zap onto, but it's not like it's twisted or corroded beyond belief. If you're curious if any other spots are weak, smack around hard with a hammer - if you make a hole, it's shot. Redneck way of testing integrity but it's fool proof, somewhat.
PA is in the salt belt, yeah? Might be worth it to do a good inspection |
In my exp when to see/find this type of rust damage it's not isolated and even if u fix ur current issue more will arise, U can not weld rust... anything can b fixed $ but is it worth the cost.
Welding time, then I'd work on painting the frame :)
https://uploads.tapatalk-cdn.com/202...8d58b1a4ec.jpg
A member suggested this for the repair. And I can weld mig and TIG and stick. I have a millermatic 130. Sent from my iPhone using Tapatalk |
Not the end of the world. Fix it if you like the 4runner
That kit will work. I just build my own. :) You can fix this and that's didnt come off bad. :)
Sent from my SM-J337V using Tapatalk |
I’ll need to drop the tank and axle and maybe the running board. I expect problems with the running board and gas tank.
Quote:
I mostly pull the tank return line as use my fuel pump to empty the tank. While you have that down. Check it all over with the filler tubes for issues. That inner rail next to the tank will most likely be rusted out. Sent from my SM-J337V using Tapatalk |
If you're anal like most I'd recommend a 220 welder, I used a Lincoln 120 at my house for my panhard correction brackets and it was unnecessarily shitty. Still got proper penetration, barely, but MAN does it look sloppy
Just my 2 cents |
Copyright ©2000 - 2024, vBulletin Solutions Inc.
DragonByte SEO (Pro) -
vBulletin Mods & Addons Copyright © 2024 DragonByte Technologies Ltd.
User Alert System provided by
