Old 05-14-2015, 11:14 PM #1
BTSullivan91's Avatar
BTSullivan91 BTSullivan91 is offline
Real Name: Brandon Sullivan
BTSullivan91 is on a distinguished road
Question Is my 4 Runner "Gear Hunting"
Hey everyone! First post here.. I've tried to find my problem w/ search and saw "gear hunting" mentioned a few times.
I have a 2014 T4R Trail Premium, with 10,700 miles. Just bought er two days ago from a local dealer. I love it to death. However, I am feeling/noticing something weird and I am not sure what it is.. After a ton of transmission issues with my Jeep, I went into panic mode.
I've noticed at higher speeds, like 75-80 on interstate, when I go up a hill, it will downshift.. It runs right at 3k RPM.. But, when I get to top of the hill, or even begin going downhill, it stays in this gear... I've tried switching into manual shift and going up into 5th, and nothing happens.. It shows 4th when I switch to manual... If I hit the brake, it will shift instantly.
Is this "gear hunting" -- If so, what is that? Is it bad? I know enough to be dangerous but that's about it.. Wanting some input from the experts... Thanks!!
BTSullivan91 is offline   Reply With QuoteReply With Quote
Old 05-15-2015, 11:37 AM #2
Ron4RNevada's Avatar
Ron4RNevada Ron4RNevada is offline
Real Name: Ron
Ron4RNevada is on a distinguished road
Real Name: Ron
You probably DON'T have any problem. If you are trying to go eighty miles an hour uphill the truck needs more torque to maintain that speed. Thus 3000 rpm in 4th gear. Putting it manually in 5th is only telling the tranny ECU that you are allowing it to shift up after it has crested the hill and no longer needs to be applying more torque.
In manual mode it will NOT shift to a higher gear. Manual mode is actually a TOP GEAR LIMITER: You can manually shift down gears but it won't shift up if the transmission ECU is telling it that it needs more torque.
Now then if you are in 4LO and crawling off-road say at 5mph you can use the manual mode to go into any of the five gears as long as you are not trying to crawl up a really steep hill where more torque is needed.
I hope I haven't confused you.
Totally stock 2013 SR5 4WD. Have added Toyo Open Country M/T LT 265/70-R17 (E) tires the first week I owned it. Added second set of Toyo M/Ts at 86900 miles.Added RCI OFF-ROAD Rock Slidersat 84000 miles. Added RCI OFF-ROAD front skid plate at 90,000 miles. Daily driver and so far spending about 30% of time/mileage off-road. Previous truck 2004 Land Rover Discovery that also spent about a third of it's life off-road. I HANG AROUND HERE "THE T4R FASHION FORUM" JUST FOR LAUGHS.
Perfect vehicle as it stands for northern Nevada terrain. Keep it stock - it'll go most anywhere as is.
Ron4RNevada is offline   Reply With QuoteReply With Quote
Old 05-15-2015, 11:59 AM #3
Thanks for the info!! That makes sense.
I guess it just bothers me that it does it even when it flattens back out.
Also, say I have cruise at 75mph, and I have to slow down for something.. When I hit resume, it will go (eventually) to right at 3k RPM's and sit there in whatever gear that is, even on flat land.. For miles and miles.. As soon as I hit the brake it will shift, or if I romp it.. Part of me is just angry that it's sucking more fuel I assume at those RPM's (reflected in the MPG readout too).
Old 05-15-2015, 12:13 PM #4
Real Name: Ron
Real Name: Ron
Hmmm - I've never had mine at 75mph or above. Only time I use cruise is when I'm at about 60mph driving the straight flat 25 mile road between Fernley and Fallon Nevada. That's when I can get it to 23 miles per gallon. There is one RR overpass and it will shift to 4th while in cruise and then will immediately shift back up to 5th at the top of the overpass.
Maybe you should have the dealer take it for a spin at 75 mph with the cruise on. Might be a cruise control issue.
Old 05-15-2015, 12:21 PM #5
2014 Warthog's Avatar
2014 Warthog 2014 Warthog is offline
2014 Warthog will become famous soon enough 2014 Warthog will become famous soon enough
Just to confirm that that is completely normal behavior. When doing a steep hill climb where you really pushed down on the skinny pedal to make it go, it goes into a "power" mode (OD off?) till it decides to drop back to economy (OD) mode again.
I agree it's a tad annoying as it seems to take it's time dropping back to eco mode. I would manually use the overdrive switch on my tacoma to perfectly time when I wanted OD On/Off in those situations and I would definitely turn OD back on far sooner than the trans seems to automatically be doing it in this case.
BUT, yes, totally normal!
The Warthog
Too many mods to list See my build thread ---\/
http://www.toyota-4runner.org/5th-ge...re-thread.html
2014 Warthog is offline   Reply With QuoteReply With Quote
Old 05-15-2015, 12:51 PM #6
Real Name: Ron
Real Name: Ron
Thanks Warthog.
As I rarely put the throttle to the floor - generally manually shifting down - I wasn't aware of this mode.
Old 05-16-2015, 12:28 AM #7
dawudih's Avatar
dawudih dawudih is offline
dawudih is on a distinguished road
dawudih's Avatar
My 2015 trail downshifts when I go downhill too. I think there is a level sensor controlling this.
dawudih is offline   Reply With QuoteReply With Quote
Old 05-29-2020, 05:33 PM #8
Jables Jables is offline
Real Name: Justin
Jables is on a distinguished road
Real Name: Justin
Gear hunting
I'm srry man I know exactly what you are talking about and without experiencing it it would sound normal but my sport is doing the exact same thing I never noticed it b4 and all the sudden it just started dropping gears while going down hills or even when i let off the Gas wich is normal but I don't think it's normal for an rpm spike and its definitely worse with the ac on it doesn't do it all the time but sometimes it even does it at low speeds pulling into a parking lot there's no issues shifting up or cruising on the highway it's only downshifting and it really is annoying i dont have any trouble codes but I do have an abs light on i think due to a speed sensor I don't think this would be relavant but I'm not a toyota tech srry i couldn't be more help but go with your gut if you think something is wrong there probably is there's a lot of very knowledgeable pple on here but they can't drive your truck and experience what you are
Jables is offline   Reply With QuoteReply With Quote
whats the difference with "GL" and "SAE" in gear oil 4Runner_101 3rd gen T4Rs 2 04-16-2014 02:35 AM
concerns about "new radiator" when hunting for new 4runner Jc12 3rd gen T4Rs 7 03-24-2014 12:52 PM
Visor Transfer Gear Shifting Cheat Sheet, Not a "how does 4wd work" thread the4tion81 3rd gen T4Rs 2 03-05-2014 01:20 AM
Gear Oil to Prevent Gear "whine" - suggestions? BIG 4th Gen T4Rs 5 11-18-2010 11:54 AM
Toyota Hilux, "Top Gear" Climb Icelandic Volcano Just Before Eruption IntoTheVoid General Discussions 4 04-23-2010 09:10 PM
