Old 07-23-2015, 06:21 PM #1
mob2rhyme1's Avatar
mob2rhyme1 mob2rhyme1 is offline
mob2rhyme1 is on a distinguished road
mob2rhyme1's Avatar
2011 4runner 4LO flashing with check engine light
I started my 2011 toyota 4runner with 56k miles on it and I saw that the Center differential lock indicator and Slip Indicator with Check engine light are displayed in dash board. I scanned for error codes and it reads; multiple cylinder missfired, Open or short in REAR speed sensor LH/RH Circuits and Engine control system malfunction. I replaced all spark plugs, replaced the engine Air filter and completely drain the tank of gas and cleaned it dry before refueling. Started car again and light came up on dashboard even while still in parked position without moving car. Anyone with idea on what could be the cause?
mob2rhyme1 is offline   Reply With QuoteReply With Quote
Old 07-24-2015, 01:25 PM #2
Northern-Runner's Avatar
Northern-Runner Northern-Runner is offline
Northern-Runner is on a distinguished road
I had the same issues with my 2011 and it turned out to be an O2 sensor. It took the dealership 2 attempts to figure out the issue.
2011 Limited Bone Stock.......for now
Northern-Runner is offline   Reply With QuoteReply With Quote
Old 07-27-2015, 08:55 AM #3
mob2rhyme1's Avatar
mob2rhyme1's Avatar
Thanks for your response. which of the O2 sensor are u referring to?
Old 08-03-2015, 09:01 AM #4
ChaosStarter ChaosStarter is offline
ChaosStarter is on a distinguished road
That "open/short in rear" code is an ABS code. No oxygen sensor will trigger that. I've seen a couple 5th gen's that needed that rear ABS sensor harness that goes from the body to the differential and speed sensors on each rear wheel. The trucks were stock too.
2005 4R V8 4x4 Limited - LEDs, FX-Rs, Gibson exhaust, TRD Red Front/Rear shocks, OME front springs, Toyotec rear springs, BF Goodrich 275/70/17 K02s, 1.25" Spidertrax. Front/Rear Polyurethane sway bar bushings, Total Chaos lower control arm alignment tabs. 150k miles and counting
2005 Prius - DD/Grocery getter. 250k miles and counting.
ChaosStarter is offline   Reply With QuoteReply With Quote
Check engine light, slip indicator light & flashing 4 Lo light croat5280 5th gen T4Rs 19 06-11-2020 05:16 PM
Check engine light is flashing drwilmerton General Discussions 5 03-01-2014 01:49 PM
CHeck engine light flashing teachme 3rd gen T4Rs 6 10-28-2013 11:21 AM
92 4runner check engine light skillzo1 Classic T4Rs 5 08-10-2011 09:48 PM
Flashing Check Engine gapboi210 3rd gen T4Rs 3 06-26-2007 02:21 AM
