New 4th Gen owner ABS Problem Youtube video of problem
soloone
I think...
Just picked up the 2007 Limited V6. It was doing this during my test drive and allowed me a negotiate a lower price. I am having problem and in the manual i downloaded i cant find this specific part. As you can see in the Video below, the Compressor or pump (Gold mechanism)) seems to be on a constant cycle. I think it is the break booster that should cycle when pressure is needed... but not every 5 seconds.
Any clue to what the part is?
Better question - Any clue on what the solution is?
<iframe width="420" height="315" src="https://www.youtube.com/embed/m4kGovOCYk8" frameborder="0" allowfullscreen></iframe>
<iframe width="420" height="315" src="https://www.youtube.com/embed/bbd390uK3Is" frameborder="0" allowfullscreen></iframe>
That gold thing is the pressure accumulator. It sits on top of the brake booster pump. Either the accumulator isn't holding pressure or you have air in the system.
Do your research, I am a 03 & 04 expert. But I bought a complete system like yours from a salvage guy that didn't know things changed in late 04. Guaranteed to fit. So I have a complete unit if you need one! The early models cost $2,000 new. I hope you got a great deal.
Thank you sir! This will get me started.
fixed.
Turns out it was the Pressure Accumulator. Easiest to fix was to replace master brake assembly. it was $2k parts cost from dealer. Found one for $350 from the salvage yard. $150 to install.
Other Part Number:47025-35070
Manufacturer Part Number:89541-35050
Interchange Part Number:47050-35030
fixed.
So glad it worked out for you!:clap2:
