Old 09-25-2015, 02:22 PM #1
Ocean Racer Ocean Racer is offline
Ocean Racer is on a distinguished road
Exclamation 2007 V8 4Runner - Engine Quirk 2000-2500RPM
I have been having a problem with engine/transmission performance about a year. Only in the 2000 to 2500 rpm range does this occur. No check engine lights or codes are thrown. Been to dealer several times and they have not a clue but witness the problem. Engine bogs down or hesitates/surges only in that RPM range. Otherwise runs perfectly. Mileage seems to be going down.
So far we have:
Replaced Spark Plugs,
Timing Belt
intake clean
Removed K&N intake to OEM intake
Reflashed ECU several times (no Difference)
Pulled the Traction Control connection (makes no difference)
Has Borla Catback exhaust still installed. 2 inch leveling kit, 33.2 inch General AT2 tires, stock wheels.
I am thinking it could be torque converter clutch or a Cat Convertor partly plugged up but would think it would throw a code if that was occurring. Any ideas or experience with this. Please help!
Ocean Racer is offline   Reply With QuoteReply With Quote
Old 09-25-2015, 02:25 PM #2
This is the engine
2007 V8 4Runner - Engine Quirk 2000-2500RPM-img_2403[1]-jpg
Old 09-25-2015, 03:09 PM #3
I have also tried 87 to 93 octane fuel, no change. Ran 44k and bottle of injector cleaner, no difference.
I am still leaning towards exhaust or transmission problems now. The tranny flush is about 250 at Stealership, they believe it will help.
I more leaning towards gutting cats, but the Under Dog Racing Modules don't seem to be available for 2007 up. Something to do with the O2's and programing uses all 4 o2 sensors, front and rear (sometimes).
Old 10-02-2015, 11:44 AM #4
Bump!! Ttt
No one has any ideas?
It went back to Toyota dealership again this week. They took snapshots from the ECU while driving to send to Toyota Engineers.
The master tech is leaning towards a solenoid or torque convertor still.
Another tech at another dealer thinks problem is related to torque convertor clutches and that doing a transmission flush will help.
Hopefully I will bring closure to this problem soon and not have to through $1000+ into a new torque convertor. Gonna fix this thing hell or high water though!
Old 10-05-2015, 08:56 PM #5
swiftneed swiftneed is offline
Real Name: Danny
swiftneed is on a distinguished road
Real Name: Danny
the slight bogging
I had a slight transmission issue at one time where i felt a tiny bog or hesitation and slipping at a certain rpm when I shifted to a lower gear, I then took my 2003 V8 with 148k, then when it happened about 138k,, I changed the transmission oil and, the diffs oil, haven't had a problem since. good luck I took it to my castrol quick lube place
swiftneed is offline   Reply With QuoteReply With Quote
Old 10-05-2015, 09:38 PM #6
46runner's Avatar
46runner 46runner is offline
46runner has a spectacular aura about 46runner has a spectacular aura about
46runner's Avatar
In my sig is a write up on how to do a transmission fluid exchange. $250 sounds reasonable.
46runner is offline   Reply With QuoteReply With Quote
Old 10-05-2015, 09:46 PM #7
Yson07SR5's Avatar
Yson07SR5 Yson07SR5 is offline
Yson07SR5 is on a distinguished road
Yson07SR5's Avatar
Try replacing the MAF? I've experienced certain airflow ranges to go dead on my Subaru's MAF, which greatly complicated tuning. Cleaning wasn't enough, had to be replaced.
Yson07SR5 is offline   Reply With QuoteReply With Quote
Old 10-06-2015, 12:28 AM #8
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
Clean the MAF. KN filter tend to let small particles of dirt in and the oil in the filter can make the MAF sensor dirty. Be sure to use MAF cleaner only!
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
V8Man is offline   Reply With QuoteReply With Quote
Old 10-07-2015, 09:28 AM #9
ben550's Avatar
ben550 ben550 is offline
ben550 is on a distinguished road
ben550's Avatar
Check/clean the MAF first.
Do a transmission fluid exchange next.
Only mess with the transmission as a last resort.
I performed $3,500 worth or repairs to a transmission the mechanic said needed to be done to fix the problem and the end result was no change... I highly doubt the transmission needs repairs...
Sounds like they are jumping right into the most expensive repairs without first attempting the simple fixes.
'01 SR5 3.4 V6 4WD
'04 SR5 4.0 V6 2WD
'07 Tacoma 4.0 V6 4WD
'06 Sport 4.7 V8 4WD
'10 Limited 4.0 V6 4WD
ben550 is offline   Reply With QuoteReply With Quote
Old 10-08-2015, 09:38 AM #10
I did the intake cleaning/MAF at Toyota and it made no difference. I also switched the K&N intake tubing back to stock air box. No difference. I could try to replace the Sensor as well.
I have gotten dealer to take readings with the Computer hooked up which they sent to Toyota Engineers for help. I believe my next move will be the solenoids and or Fluid Change. The Torque converter is more than $1,000.
Keep the ideas coming and I will report back as well.
Old 10-13-2015, 09:15 AM #11
I can't get the dealer to even call me back about what they recommend. So with out further delay I plan to do:
1) Replace MAF sensor and put my K&N intake back on
2) Change the Transmission and Differential Fluids/Flush
And hope for the best. Quite a few Mechanics seem to think the torque converter clutches or the solenoids are giving me problems.
Old 10-21-2015, 09:14 AM #12
MAF sensor replaced, Front Diff/transfer case fluid changed, and did the Transmission Flush/Fluid exchange at the Stealership. $711 worth! NO CHANGE...
So next step is to change the torque convertor and possible shift solenoids. I don't want to guess what this next bill is going to be. I hope I lick this thing soon! Tired of chasing this unicorn. Been working on this nearly a year.
Old 10-22-2015, 11:42 AM #13
Davy180's Avatar
Davy180 Davy180 is offline
Real Name: David
Davy180 is on a distinguished road
Davy180's Avatar
Real Name: David
Sorry you spent that money and it didn't fix it. When you say bogs / hesitates do the RPM's drop or do they stay steady even though you are trying to accelerate?
Are you able to catch this on video? That might help us diagnose this a little better. Also are you able to get them to print out the freeze frame data and post it here?
2006 T4R Sport 4WD V6 - Bilsein 5100 Shocks, Toytec 2.5" lift front coils, SuperFlex rear coils, Toytec front diff drop, Icon sway bar relocation block - BFGoodrich AT KO2 275/70/17 - Spidertrax 1.5in wheel spacers - DDM 6k low beam headlights & 6K dually ditch lights - Scion FRS radio - Custom rear sway bar end links
Build Threadhttp://www.toyota-4runner.org/4th-ge...ld-thread.html
IG: Davy180
Davy180 is offline   Reply With QuoteReply With Quote
Old 10-22-2015, 03:13 PM #14
46runner's Avatar
46runner's Avatar
Seafoam?
Old 11-06-2015, 04:16 PM #15
I will ask them to give me a copy. And I will try to take a video, its pretty subtle, but I am zoned in on it because of the exhaust sounds/Borla and I can feel it all the time, the guys at the dealer claim they don't feel it at all.
The RPM's do jump a little (down) maybe 100 RPM. It honestly feels like something is grabbing. So its got to be shift solenoids or torque convertor. Don't you agree? Again under hard acceleration this problem doesn't occur.
2007 , 4runner , engine hesitation , v8 engine
2000 4Runner Check Engine Light HELP! N8Dawg Engines / Suspension / Wheels / Tires / Audio / Accessories 0 05-18-2013 05:32 PM
check engine light 2000 4runner 3RZ-FE PossumJenkins 3rd gen T4Rs 10 03-13-2011 05:02 PM
My 2007 v6 4runner engine blew 6starbucks 4th Gen T4Rs 90 02-16-2011 09:03 PM
Engine Vibration at 2500RPM Iowabaydog 3rd gen T4Rs 3 05-23-2008 09:03 AM
