Old 11-27-2007, 09:56 AM #1
LAR_414 LAR_414 is offline
LAR_414 is an unknown quantity at this point
2001 4run, check eng light, code P1135 ????
About a week ago, my check engine light and the VSC lights (both) came on. And they've stayed on.
I've opened and closed the gas cap. I've disconnected the battery and then re-attached it.
Lights are still on. MY 2001 SR5 4runner runs (seemingly) just fine.
I stopped at an Advance Auto parts, and borrowed theire OBDII scanner tool. Here is what it came up with, for a code.
P1135
Manfacurer Contrl.
Fuel Air Metering
What do you think this means? I'd like to do my own repairs, and this is my first problem with a check engine light on a newer vehicle. I'm used to working on muscle cars and race cars.
Thanks,
LAR_414 is offline   Reply With QuoteReply With Quote
Old 11-27-2007, 02:08 PM #2
Another forum states that this means that the oxygen sensor before the cat converter needs replaced (driver's side???).
Does this seem right?
If so, who has the best / cheapest ones out there?
Will the code reset after the fix?
Old 12-06-2007, 09:43 AM #3
Boy does this board seem useless!
No one could help me out.
Don't worry, I figured it out with the help from a better board, and it's not even a Toyota board.
Old 10-26-2011, 10:32 PM #4
neilpalpallatoc neilpalpallatoc is offline
neilpalpallatoc is on a distinguished road
2001 4runner P1135 code
Hi,
Can please anyone help me with this problem. Yesterday the lights came on both vsc and check engine light. I was told that it's an O2 sensor and the forum says air/fuel meter sensor. I'm confused and I want to make sure I solve the correct issue. Thanks very much for your time.
neilpalpallatoc is offline   Reply With QuoteReply With Quote
Old 10-27-2011, 02:12 PM #5
Acidmeld's Avatar
Acidmeld Acidmeld is offline
Acidmeld is on a distinguished road
Acidmeld's Avatar
Its the bank 1 sensor 1 air/fuel sensor. Replace it. An air/fuel sensor is a newer design of an o2 sensor.
2007 SportEdition V6 4WD Galactic Gray
Found on the trails of the Colorado front range
Daystar 2.5/1.5, Rear Diff Breather Mod, TRD Brake Pads, Full Synthetic 90w-135 Gear Lube, 265/70/17 Duratracs, Cobra 75, 3' Firestik, Refrigerated Console
Toyota Expert Tech/Lexus Certified Tech/ASE Master Tech
Acidmeld is offline   Reply With QuoteReply With Quote
Old 01-29-2012, 01:06 AM #6
goldshield1 goldshield1 is offline
goldshield1 is on a distinguished road
Originally Posted by lar_414 View Post
about a week ago, my check engine light and the vsc lights (both) came on. And they've stayed on.
Lights are still on. My 2001 sr5 4runner runs (seemingly) just fine.
I stopped at an advance auto parts, and borrowed theire obdii scanner tool. Here is what it came up with, for a code.
P1135
manfacurer contrl.
Fuel air metering
what do you think this means? I'd like to do my own repairs, and this is my first problem with a check engine light on a newer vehicle. I'm used to working on muscle cars and race cars.
Thanks,
replace down stream sensor on exhaust
goldshield1 is offline   Reply With QuoteReply With Quote
Old 03-19-2012, 01:50 AM #7
BrianSD_42's Avatar
BrianSD_42 BrianSD_42 is offline
Real Name: Instagram: briansd_97r
BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice BrianSD_42 is just really nice
BrianSD_42's Avatar
Post in the /3rd Gen/ section.
Everyone with a 3rd Gen is there to help.
Edit: AHHHHH 2007, I got trolled.
Those he commands move only in command, Nothing in love. Now does he feel his title, Hang loose about him, like a giant’s robe, Upon a dwarfish treasonous thief.
BrianSD_42 is offline   Reply With QuoteReply With Quote
Old 04-15-2012, 12:45 PM #8
joncee52 joncee52 is offline
Registered User
joncee52 is on a distinguished road
Registered User
Just a note that you can get this sensor (save $) on Amazon http://www.amazon.com/s/ref=nb_sb_no...Oxygen+Sensor+
It is really an easy fix to with two bolts and a wire connector only and the check engine light will go off along with the vsc indicator.
Last edited by joncee52; 04-15-2012 at 01:20 PM. Reason: Updating the url and adding a repair note.
joncee52 is offline   Reply With QuoteReply With Quote
Old 04-15-2012, 12:58 PM #9
Igot1too's Avatar
Igot1too Igot1too is offline
Igot1too is on a distinguished road
Igot1too's Avatar
Hopefully after 5 years he figured it out.
2000 SR5 4X4, Desert Dune, 5th Gen 17" TRD Wheels
275/70-17 Falcon Wildpeaks
Tundra front springs, OME 906 rear springs
Bilstein 5100s
268k miles so far...
Igot1too is offline   Reply With QuoteReply With Quote
Old 03-24-2016, 01:38 PM #10
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Sooooo is this an O2 sensor thing for sure?...
Or just one possible issue?
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Check engine light, VSC TRAC & TRAC OFF lights crainmain Maintenance/Detailing 121 10-23-2025 12:43 AM
Reset check engine light conedodger 3rd gen T4Rs 22 10-03-2020 10:56 AM
VSC off, TRAC off and check engine light on! swimmer2361 Problems & Warranty Issues 78 09-01-2020 10:21 PM
VSC off light \ TraK and Check Engine light on Nedlob Problems & Warranty Issues 18 12-30-2015 09:44 PM
More info on VSC and Trac OFF light with Check Engine light Trump Tight Problems & Warranty Issues 1 05-18-2008 11:55 PM
