blinkers and hazards not working
4runna08
this happened a couple days ago. when you engage the blinker you hear a tick. when i start the car there is a zzzzzzzzz noise coming from the fuses. but the fuse isnt burning.
i also checked the harness to the hazard button
Have you checked the bulbs?
ok i changed the relay and my hazard works but not left and right. only the right side flashes and my turn signals still dont work
i checked my bulbs and none are burnt. when i put my hazards the left side doesnt flash. maybe it has something to do with the wiring??
since it seems to me that you have an 08 then it should be under warranty, I'd take it back to the dealer and have them try to pin point the problem. Even if you didn't have a warranty still on it, I'd take it to the dealer and see if they can pin point the problem. Just my .02 cents worth.
negative. i have a 98. i ve gotten the blinkers to work. but when i push the hazard, only the right side flashes
