Old 10-15-2009, 11:45 PM #46
ProMed's Avatar
ProMed ProMed is offline
ProMed is on a distinguished road
ProMed's Avatar
Originally Posted by rgcary View Post
My only concern about going to Toyota for my appt is for them to check it out AND come back w/a bill for $155 just for taking the panel off just to tell me it's a bulb.
As I said, my dealer just replaced the entire unit. I doubt they ever considered replacing an led behind the panel.
March 2008 T4R of the Month
ProMed is offline   Reply With QuoteReply With Quote
Old 10-16-2009, 10:20 PM #47
rgcary rgcary is offline
rgcary is on a distinguished road
Smile Thought you would like to know.
Originally Posted by ProMed View Post
Let us know what you find out. They replaced the entire panel on mine during the standard warranty period around a year ago. It is now starting to flicker again and I have the extended warranty as well.
I'm not going to the dealership Sat. morning because the bulb is not under warranty. I replaced the bulb in about 10 min max. The cost of the bulb was $5/each at the Toyota dealer. I tried Radio Shack as some mentioned, but they did not have that size bulb and if they did I'd be worried about using it against that control board if it's not exactly right. The other posts about taking the HVAC area apart is very true about pulling on it until you hear the pop. I thought I cracked it, but it was just coming unsnapped from the back on the top and bottom. There are two hooks on the top and bottom. So all is well and the new bulb is in. It's very easy and all you need to do is look at the diagrams posted on this link.
Good luck and thank you again for the tips. You saved me a lot of green!
Titanium 2005 4Runner Limited v6 4wd; X-REAS removed @ 115,000 miles & 5100's set to .85" w/FJ coils installed all around.
rgcary is offline   Reply With QuoteReply With Quote
Old 10-23-2009, 11:25 AM #48
03dfw4runner 03dfw4runner is offline
03dfw4runner is on a distinguished road
Same here! Mine was flickering & the average miles driven was showing like 0- 15 miles no matter what , So they just replaced it the whole unit ....... Hopefully it does not go out again, I really like the look of the blue light mod on these ... But have no time to switch out to all blue so staying amber for me.....
03dfw4runner is offline   Reply With QuoteReply With Quote
Old 10-28-2009, 09:07 AM #49
Unhappy Another light just burned out...
This time it was the defroster light. If the dealer had more in stock at the time I bought the other one I would have repaced all at once...
Old 11-25-2009, 12:36 PM #50
ALLEGRO's Avatar
ALLEGRO ALLEGRO is offline
ALLEGRO is on a distinguished road
ALLEGRO's Avatar
Do you have a "how to" on this. I want to fix it, but I do not want to mess anything up at all.
2007 Driftwood Pearl Limited
ALLEGRO is offline   Reply With QuoteReply With Quote
Old 11-25-2009, 12:55 PM #51
Smile It's a 5 min job.
It's very easy and don't pay anyone. There was a thread earlier out there where someone took screenshots. I don't have the link handy right now as it's at home. Keep in mind I have a 2005 4Runner so I'm going off that. If you lift up on the storage area when opened just below the HVAC controls it will easily be removed with no snaps, screws, etc. From there you will see one screw behind that to remove which is all you need to take off the HVAC and info panel as one part. This is where I get worried because you have to pull out and unsnap the 3-4 clips. There are 2 clips on top. When they unsnap it sounds like they're cracking, but they're not. I would try your best to pull toward you and not up because they fit straight in and not at an angle.
Once this is done all you need to do than is find a VERY small screwdriver and unscrew the lights you need to replace. You're done!
Email me if you have problems or need additional info.
Here is another post that wil help too!
'05 4Runner dash lights flickering?
Happy Turkey Day!
Old 01-19-2010, 08:48 PM #52
bobodude bobodude is offline
bobodude is an unknown quantity at this point
I had one of these lights go out on my info panel on my 2005 limited. My dealer wanted $150 to replace the bulb. I about fell over. After reading this forum I bought this cheap plastic pry bar set from Harbor Freight for about $5. Hopped in the front seat and opened the drop down clutter catcher box just below the temp controls. You can see a phillups screw that is sort of recessed under the panel. Just unscrew that and remove the screw. Now the panel is held in with pink teflon fingers. Don't be shy because these are pretty hefty and you can't break them unless you really yank on it. I just slipped one of the pry bars under the lower finger and it just "pops" out. Sounds like you broke something but that is the sound it makes. Then pop the other side up and then carefully slide your hand under the panel and yank the top fingers straight out. Don't bend it up but pull straight out. Once it is out you'll say "Geez that was easy". I disconnected the whiter connector by pushing in the release tab and pulling the cable loose. This takes a bit of muscle as they are pretty tight. Take the whole panel in the house and under a good light you will see 3 lamps behind the info panel. Take a small screwdriver blade and turn them counter clockwise until they stop. Then using a pair of tweezers, pull them out. They will not fall out if you turn it upside down, you have to use tweezers to remove them. Slip the replacement in and turn clockwise until it stops. Sooooo easy. Plug the white connector back in and carefully align the fingers back in the holes, starting at the top. Just push the panel in until you feel it snap in place. Insert the phillups screw and your done. I took me about 10 minutes. Piece of cake.
bobodude is offline   Reply With QuoteReply With Quote
Old 09-08-2010, 04:08 PM #53
clem18's Avatar
clem18 clem18 is offline
clem18 is an unknown quantity at this point
clem18's Avatar
I just had the light on one side of the panel go out on mine. Thinking I have an extended warranty that maybe the dealer would cover it. Well, no chance, since it's a bulb that would need to be replaced and not covered. They want to charge $110 for a $3.60 bulb. I was not even happy buying the bulb from them lol!
clem18 is offline   Reply With QuoteReply With Quote
Old 10-08-2010, 08:51 PM #54
RHINO-99 RHINO-99 is offline
RHINO-99 is an unknown quantity at this point
Info panel not lighting up???
My right side of the information panel (temp, mpgs etc.) stopped lighting up. Its working but not lit up so Im assuming a bulb is out. I have an extended warranty on a CPO's 4th gen. Will this be covered or how can I fix myself? Thanks
2006 4Runner Sport Edition V8 4WD
RHINO-99 is offline   Reply With QuoteReply With Quote
Old 10-08-2010, 10:15 PM #55
bulb.
I don't think it will be covered under warranty. I tried under my toyota ext warranty and no go. The bulb is less then $20 and you can replace them in about 15 min. There are threads out here on how to do, maybe under my name and others. It's very easy on y '05 to replace, don't pay anyone... Get used to them going out. My down hill assist button light is out now, but I'm not replace it yet.... Info panel left side if flickering now, probably go out sometime soon. The bulb looks like an led light and very small.
Old 10-08-2010, 10:31 PM #56
Ok. Thanks. Could you post a link as to how or what bulb I need and where I can find the bulb? I'm new to the forum and have a hard time finding things. Thanks again.
Old 10-08-2010, 10:34 PM #57
Smile Directions at top of thread.
You'll need to take it apart to find the correct bulb #. I bought mine at Toyota dealer, though I searched everywhere to buy elsewhere because they mark their prices up. Radioshack did not have one.
Old 10-12-2010, 03:15 PM #58
Originally Posted by HPK View Post
Took a couple pics with a green LED installed on one side. Looks great compared to the crappy orange color...I'd like to find a couple blue LEDs tho.
Quick and painless as mentioned in a previous thread. Back out the one screw in the little "cubby" and sort of pop out (I started from the bottom, where the screw was) the A/C panel. I labeled where the two sockets are for the issue at hand.
Might need to figure out how to get a resistor inline with the anode (longer leg of the LED, positive leg) to keep the heat/intensity down. I took that pic with pretty decent daylight and look at the brightness. During nighttime driving, it would prolly be a lil annoying.
Note: the bulbs can be found at radioshack I believe, but so can the LEDs.
Note2: you can replace most, if not all the bulbs on the back of this panel...I'm thinking about installing all blue LEDs.
I'll post more pics if I decide to proceed with LEDs.
Until next time...
Is it ust the one screw I need to take out and then pop this piece off to get to the bulbs or do I need to take aprart the entire dash/console?
Old 10-12-2010, 03:20 PM #59
Thanks. Im going to try it tonight. I got the light. I always hate yanking on that plastic. So basically, its the one screw and then the rest just pops off corrct? Thanks in advance.
Old 10-27-2010, 07:39 AM #60
Ridger's Avatar
Ridger Ridger is offline
Ridger is on a distinguished road
Ridger's Avatar
This forum is awesome!
This is the one thing that was not working on my new 4Runner; I'm going to go get the bulbs today at the Toyota dealership and try installing them myself in the next couple of days.... thanks to this thread.
2006 Limited V8 4X4 - Driftwood Pearl (purchased 10/22/2010)
Amsoil Synthetic Fluids l Husky Floor Liners l Rear Cargo Area Backup Mirrors l Highland Cargo Barrier l Extra 12V Outlet Mod
Ridger is offline   Reply With QuoteReply With Quote
HELP! Selling 4runner but have Climate control LCD Backlight Issues! dannycwu 4th Gen T4Rs 5 01-12-2011 09:19 PM
Half light off on the display panel for clock, gas and MPG info nedzad1 4th Gen T4Rs 4 02-23-2010 06:58 PM
A/C panel backlight bulb burned out Atlanta_man Problems & Warranty Issues 2 08-06-2009 12:21 AM
Incandescent or LED instrument panel backlight? dman90012 4th Gen T4Rs 1 06-09-2004 02:43 AM
