Battery Specs - Stock Panasonic 105D31L
shuly
Thought I would share this with the group. Took forever to finally find this. I was originally trying to figure out the CCA of the stock 4th gen battery 105D31L-MF. This info doesn't seem to be anywhere. I found this old post but seems no one else had an official answer.
The old post was:
http://www.toyota-4runner.org/showthread.php?postid=105977
Anyway....Here is a link to the panasonic malaysia site:
http://www.panasonic.com.my/web/pid/1745
This appears to be the specs for the batteries in our trucks :) Hope this saves someone some time.
Just in case the link ever fails:
PBTH'S Model New Jis TC-105D31L
Volt 12
CAPA 20HRS (AH) 90
Plate Per Cell 19
Max Dimension (mm)
L 306
W 173
H 204
TH 227
Weight Without Acid (Kg) 17.5
Approx Acid Per Battery (L) 5.0
Assembly Figure - +
Terminal Type Big
Container Material Plastic
Normal Charging Rate AMP. 8.0
Reserve Capacity Minutes 165
CCA 710
CoaterZ_FL
