1.5" non hub centric spacer w/stock wheels question
Ph3n0m427
I have a question for the ones running 1.5" non hub centric wheel spacers and stock wheels. did you guys install hub centric rings and if not do you guys experience vibration?
I did for a while. I didn't have any vibration. But I took them off when I got my new wheels and sold them. If I ever get spacers again I will go hub centric for sure.
The non-hub centric relies on an acorn lug nut to center them on the studs. You have to go slow and tighten them so that it actually can center it up and I would suggest torquing them to spec, 90 ft/lb I believe. I have non-centric and haven't had any vibration, but hub-centric is definitely the way to go there. They get there support from the center instead of the lug nuts only and are safer. Worth the money really.
Yeah, my post was brief, but I had my tires balanced twice until the vibration went away. It's just an easy thing to eliminate from future troubleshooting. I'm probably going to get spidertrax from toytec within a month.
BillM777
