1st gen 31's with 1 inch offset
mschlee
from everything i've read i believe i will be fine, but want to check if anyone knows if i will be safe with 265/75/16's on 16X8 wheels with 1 inch offset?
i'm pretty sure i'll be fine. it is the offset that is throwing me so just want to double check before i order up.
87 runner with minor lift (1.5 inch ball joint spacers in front and added leaf in rear)
thanks
If the wheels fit and spin without rubbing, with that backspacing (you will have to test fit) you will be perfectly safe.
If the referred 1" offset translates to 25mm, I don't think that will fit properly for an 8" wide wheel. If that means -25mm (negative), they'll sure fit without rubbing. Be careful about that.
