2.7 high idle and bogging
D'arce
This is a new truck and motor for me. It idles around 1000 when I first start it. Sometimes after it warms up I can restart a couple times and it may drop down to around 700. Usually its pretty happy to sit at 1k.
The second issue is a bogging down and temporary loss of power at around 2500 rpm. I can downshift (manual) and rev through it and when I up shift past 2500 all is well.
What I have done so far.
-cap and button (cracked and worn)
-plugs and wires (unknown age)
-cleaned IAC (not too bad actually)
-replaced TPS (even though the old one checked out via voltmeter)
-cleaned MAF (not dirty that I could see)
-cleaned tb (fix for sticking gas pedal)
-replaced a couple of rotten vacuum lines
-replaced PCV (just plain nasty)
-replaced leaking water pump
-cleaned battery terminals
There is no CEL. Truck has 250k miles on it. Motor runs smooth with an occasional burble. Doesn't burn oil. Getting around 20 mpg. Everything I have done so far I chalk up to basic repairs and maintenance.
I don't want to get into a habit of throwing parts at it so any suggestions would be greatly appreciated.
That Idle is not horrible. Mine also idles about 1000 or slightly less until it hits full warm temp at about 80+ degrees C then it settles in at 650 to 700.
Is yours getting up to proper temp or could you have a stuck thermostat keeping it cooler?
Sorry, no help on the bogging except a wild guess of dirty fuel filter? Not a bad idea to change it anyhow.
Good luck.
Edit: if you are not aware of the exhaust valve clearance issue with the 3rz, do a bit of reading. Not likely your problem but a good thing to know about.
Thank you for the reply...it does get fully warmed up. It is not until it has gone through a couple of restarts that the idle finally settles down when its at temp.
After a couple of short drives it feels like the hesitation is gone. I'm thinking the TPS fixed it. Without any insight into the high idle I think I'll start looking at vacuum hoses...
DionicioLives
