2002 4Runner Limited 192K miles - $8,000
98OzarksRunner
SOLD
2002 4Runner Limited - 192,000 miles $8,000.00
Selling my 4Runner since I just don't drive it enough to justify keeping it, and somebody else can get good use out of it. I have only driven it 2000 miles in the last 8 months, so it's time for it to go to a good home.
I bought this in April 2012 from a used car dealer (after looking for six months). I ran the VIN on carfax and Toyota owners. It was a one-owner car from southeastern Kansas, and apparently owned by an older couple. They had it serviced at the dealer religiously - oil changes every 3000 to 4000 miles (sometimes a little more), and ALL the Toyota recommended service done. I have the service records for it (back to 47K miles, 2005, which is as far back as Toyota online records go, but carfax shows maintenance prior to that). When I bought it the mileage was 144,000. It had a slight tear in the driver's seat (which has gotten larger), a couple of very minor dings, never wrecked, and was always garaged. I have the original factory floor mats and cargo mat. It has a CargoLogic aftermarket cargo mat as well. All in great shape. It also has NO RUST, except for a little very light surface rust here and there on the frame and suspension components (it may have rust inside the frame but I can't find any).
I have taken good care of it, but it has been run off-road. I have run down dirt roads (where does one this go?) and Forest Service roads in southwest Missouri. It has never been abused or taken to a 'let's see what we can break today' off-road park. I'm an old guy and take it slow and easy. It has been through some difficult places (I'm always amazed at what it can do) but never broken or mistreated. It did have some pin striping from tree branches (this is the Midwest) but they buffed out and only a few faint lines remain. I repainted the silver trim. I've never had this stuck or used the winch to pull myself out (I did use it to pull a friend's Taco off a fallen tree, and pull a few fallen trees off the trail). That it's never been stuck is a testament to it's ability, and my caution (or common sense, and the fact that around here it's so rocky there usually isn't enough mud to get stuck). The multi-mode transfer case with LSD is great on snow and ice - just put it in 4WD (AWD) and drive.
Options:
2002 Limited
Power, heated seats (work!)
Towing Package
Sunroof
Rear heater
Homelink (garage opener - I haven't tested that)
CargoLogic cargo mat (in addition to factory mat)
Factory alarm/keyless entry (one transmitter, 2 keys)
Here's the maintenance since I bought it:
Lower Ball Joints (Toyota), May 2012, 145K miles (had been done earlier under the recall at 53K miles, but I replaced them just in case).
Front end alignment, April 2012, 144K miles (checked again 5/2014)
Hayden transmission cooler, April 2012, 144K miles
Spark plugs and ignition wires, May 2012, 145K miles
Monroe Gas Matic shocks for LC, April, 2012, 144K miles
Wheeler's Off Road Nitro 9000 front shocks (have 58K miles on them - were on my other 4Runner)
Changed rear diff lube, April 2012, 144K miles
Energy Suspension steering rack bushings, November 2012 (miles unknown, probably about 160K)
Valve Cover Gaskets (though it still seeps, but no drips on the floor)
Fuel filter, July, 2012 (miles unknown, probably about 155K)
Timing Belt and Water Pump kit, thermostat, all belts, using OEM parts, November 2014, 186K miles (previous owner had the dealership do it at 94K)
Sears Die-Hard Platinum (Odyssey) 34M (marine) AGM battery, September 2014, 184K miles
Cooper Discoverer AT3, load range C tires, September 2014, 184K miles (have 8000 miles on them - look brand new)
Replaced the AC/heat blower motor (early 2015)
Oil and filter changes every 3000 miles
Climate control unit just repaired (lifetime warranty)
Probably more but I don't remember
Added 'Stuff' to make it more fun:
Detroit True Trac Limited Slip Differential in rear (58k miles on it) - very nice! Detroit TrueTrac 913A610, Detroit Truetrac Differentials | Detroit TrueTrac
OME 883 front springs
LC 7 7/8 wrap rear springs
Front diff drop
ARB front bumper (frame endcapped with 1/4" plates)
Warn M8000 winch (steel cable)
Homemade rear bumper with swingout tire carrier. Powdered coated ($275 for that!)
Rear axle breather extension
2nd Gen rear sway bar links
Blue Sea Systems 100 Amp fuse panel
Hella relay panel (1 used, 4 more available)
Hella 500 driving lights (switch is fog lamp switch on turn signal arm)
Storage unit in cargo area (not pretty but very secure)
Tinted windows (professionally installed)
Ultra Gauge engine monitor (mileage, temps, etc.)
Alpine AM/FM/CD/Satellite radio (about 1 year old)
Cobra CB and 4' Firestick antenna (don't know how well the radio works)
Andy mod to disable VSC/TRAC with switch
The 'issues':
Has 'the tick' (faint rattle) at 2000, 3000, 4000 RPM that nobody can figure out (several threads about that). But it's been doing it for over 40K miles so I doubt it's a problem.
The driver's seat is torn. (Lifted trucks need running boards or sliders to step up into the truck.) Small tear on passenger seat cushion, visible when door is open. Back seats are perfect.
The power steering pump moans a little when it's cold.
Has 5 or 6 small dings that should all come out with paintless dent repair.
This truck drives, handles, runs, and off-roads GREAT! I have driven it to Colorado and back (2000+ miles), and wouldn't be afraid to take it anywhere. It is comfortable, quiet, and capable. I have all the original parts (bumpers, running boards) to go with it as well. Everything works (A/C cold, rear heater works, it all works, even the power antenna).
Located in Ozark, MO (just south of Springfield).
DSC_4440_zpsi6fithg3.jpg~original
DSC_4439_zpskum5k9oz.jpg~original
DSC_4437_zpsntlsr3vr.jpg~original
DSC_4443_zpsbgtfwcuj.jpg~original
DSC_4442_zpsf0eeo8qh.jpg~original
DSC_4441_zpsm4g4opf7.jpg~original
DSC_4419_zpslubrfusq.jpg~original
DSC_4420_zpszwdhzq9e.jpg~original
DSC_4425_zpsqlguakhp.jpg~original
DSC_1632_zpsc5h2ex7v.jpg~original
DSC_4410_zpsygc08ncu.jpg~original
DSC_4413_zpsjwrrwoky.jpg~original
DSC_4391_zpsyuondj14.jpg~original
DSC_4390_zpsnzbaizcq.jpg~original
DSC_4382_zpsdrwsrncs.jpg~original
DSC_4375_zps4fjz6quy.jpg~original
DSC_4380_zpsk9xqz4ky.jpg~original
This is funny. I posted this on craigslist and their automated software flagged it for removal. They only allow you to advertise one vehicle per post. I said I had driven it to Colorado and it has Cooper tires, an Odyssey battery and a Cobra CB and I think their automated software thought I was advertising 5 vehicles - a 4Runner, a Mustang Cobra, a Mini Cooper, a Honda Odyssey, and a Chevy Colorado. :frusty:
seltzernator
