2004 4Runner still on OEM Panasonic battery
2003 still with factory battery
In Florida Batteries get crushed by the heat. With 75k on my '03 still has the original battery. I just chenged it this week, only because the damn thing is 7 years old! A couple times I wondered if I replaced it and just forgot, it's that old, but nope. It's a Panasonic!
Today is a sad day in the life of my Runner. I was out in the garage being bored and after a while I decided to start her up and back it in the garage so I could close the door. click.click.click.click.click.click.click. is all she had to say to me. My neighbor came back and jumped her and she woke right up.
So after 6-1/2 years, 92,000 miles, her battery died.
:crybaby:
I was able to make it over to AutoZone and get a new one for about 92.00 and with 8yr warranty.
:crybaby:
I am a BIG fan of AutoZone batteries. :)
My turn...... I changed out my original Panasonic in my VERY early built '03 a few weeks ago after 152,000 miles. It went dead after using the radio for a while, and I recharged it, and it continued to work fine. I decided to change it out since I'm headed out on an extended trip to the Utah wilds.
Went with the Interstate MegaTron Plus 84 month.....
Yeah me too. Probably would of replaced it with a dealer battery, but the battery did not cooperate with my plan of replacement.
Two months shy of 7 years, the battery in my 04 gave me the C.O.D. (Click Of Death) this morning, just shy of 76K miles.
Surprised it lasted this long in the desert heat.
But I sure am happy it did not happen during my fall vacation!
The battery died about a week ago on our '04 4runner with 144k on it. My '02 Acura RSX Type S also had a Panasonic in it and it lasted for about 6.5 years or so.
2006 SR5, 45300 miles. Running on OEM Panasonic battery... running HID Lows & Fogs, 0 gauge wires running 2 amps, 1 3000W and 1 250W and I can run my car on accessory playing music for hours on in and the battery wouldnt even struggle. I think these are great batteries!
My 4Runner's didn't last nearly that long, only about six years. My Infiniti though, it still had the original (I had to double-check the service tag) when I sold it at ten years old and about 106k miles. I'd never seen a car battery last that long before, not sure I ever will again. Most of mine seem to go between 5-7 years.
My 2004 SR5 will finally get a new battery today. Just shy of 6.5 years and just over 80K.
We drove it up to NC for Thanksgiving (typically in hot/humid NOLA weather), and heard the click-click-click-click for the first time ever after a 19 degree night.
Don't hate that I have to replace it, just that it's so close to all the holiday spending that has already happened!
chalk another one up for Panasonic
My '04 Limited only has 60K on it but is still ruinning strong on the OEM battery. Even with the hot summers and freezing winters here in Italy.
Still have mine at about 90K & it seems fine (knocking on wood now!!!).
Someone must be able to find a way to get these batteries here!
My wife drives a 2003 Camry SE and it still has the original Panasonic battery. Here in MPLS the temps range from -25*F to 95*F. I had the battery tested in the early spring 2010 thinking it was time but the guy at O'Reilly was amazed, it still maintains 95% of the CCA as new!
I bought my 2006 T4R in July 2009 from a small auto broker, to try and gain some sense of comfort I made the sale contingent on passing a Toyota Dealership cerified test. Well the dealer(stealer)ship said everything was perfect with the exception of the battery, it failed the load test. They wanted to replace it and they had a replacement battery in stock (salespitch!!). I told them I'd replace the battery myself but surprise surprise I took the T4R battery to O'Reilly and they said it was perfect for a 3 year old battery.
Update:
Just last weekend I replaced the Panasonic battery in the 2003 Camry, 115k miles and nearly 7 years. Not bad.
Even after a summer of record heat here in NY
LOL. Not sure what you mean by "record heat". I'm guessing 101 for a day or two? You should come to central Cali, 100 degree in summer is consider a cool day. 110 degree is hot. Now, we don't considering it breaking record until 114. :eek:
Because of the heat, Battery mfg actually rate the life expected of typical automotive battery used here in central Cali to be around 50 months. When you stop by a specialized battery shop and ask to see the published data for your area. Some shop do keep those around. Our local Walmart has a battery testing scanner that ask operator to enter zip code and final test result output does include the 50 months estimate.
B
My girlfriend and her sister: 2003 4runner each with the original battery. About 80,000 miles each.
Unreal. I want one of those batteries. Maybe a trip to Japan...
I just replaced the OEM battery on my '04. The battery still seemed fine, but I figured I'd replace it anyway because it was starting to get old. I do wonder how long it would have gone before it failed.
As the title says, my '04 is still going strong on the original Panasonic battery. Even after a summer of record heat here in NY, the battery shows no signs of dying. I did a 15-second load test on it yesterday and the needle didn't even budge!!
How long can we expect these batteries to last? Anyone else on the OEM battery after seven years?
I have a 03 v8 sr5, i just replaced the original panasonic battery this past sat. truck has 101k on it, get ur cold cranking amps tested, if your low replace it.
H.Sikina
