2004 Volkswagen Touareg/Porsche Cayenne
Cayenne:
"On the steel-sprung Cayenne S, there's 104 mm of compression and 116 mm of rebound at the front, followed by 135 mm and 98 mm at the rear. Air suspension is available as an option on the Cayenne S."
That is about 8.6 inches of wheel travel up front and 9.3 inches for the rear...unimpressive! (Just take a look at the Range Rover)
Cayenne's Engine:
According to below, 76% of torque at 1000 rpm (typical of turbo engines)
True dual exhaust! Very cool!
"The Cayenne S features a naturally aspirated version of the new 4.5-liter Cayenne V8. Maximum power of 340 hp is reached at 6,000 rpm, preceded by 310 lb-ft of torque all the way from 2,500 to 5,500 rpm. With Tiptronic S, the Cayenne S takes just 7.2 seconds to reach 62 mph with a top track speed of approximately 150 mph.
Inside the cockpit, all that data translates to a rich and engaging drive. A depth of performance that can only be achieved with genuine Porsche engineering."
Off-roading with Cayenne:
"The Cayenne was created for pure driving pleasure - no matter how unpleasant the terrain. Which is why it features one of the most advanced off-road setups ever featured on a production car.
Simply shift the transfer gearbox into 'low-range' mode, and the car is ready for off-pavement use. Porsche Traction Management (featuring off-pavement ABS and ABD) combines with Porsche Stability Management to achieve optimum traction on any type of surface. On the Cayenne Turbo (optional on Cayenne S), the air-suspension system lifts the ride-height setting to Off-pavement level for a total ground clearance of 9.6 inches. The current vehicle status is always clearly displayed at the center of the instrument cluster. If greater ground clearance, simply raise the ride-height setting to Special off-pavement level (10.7 inches) and lock the center differential.
You now have all the qualities you'd expect of a Porsche in even the most challenging off-pavement conditions. Traction is firm, the handling assured, while stability and safety are second to none.
The Cayenne chassis is more than prepared for some steep off-pavement gradients. At the highest ride-height setting, the generous approach angle of 32
"Like the Porsche 911 and Boxster, the Cayenne is equipped with internally vented discs on all four corners. This race-proven technology ensures consistent brake temperatures and therefore opti-
mum performance, even under prolonged downhill use.
The front discs are gripped by six-piston, mono-
bloc aluminium fixed calipers aided by four-piston calipers at the rear."
Keyless Entry:
"For added security and greater ease of use, both Cayenne models are also available with the new Porsche Entry & Drive System. As the name suggests, this optional system enables you to enter the car without the inconvenience of a standard key.
Whenever you want to enter the car, simply reach for the door handle. As you do so, the electronic key in your pocket communicates with the on-board system in the car, which confirms the key access code. If the correct code is found, the doors are automatically unlocked and you are able to enter the car. The entire process is totally seamless, as if the doors had never been locked.
Once inside, you can start the car using a simple key-switch on the dashboard. After checking the code on your key once more, the system unlocks the engine immobilizer and brings the car to life.
To automatically lock the car, simply press the button on the outside of the door handle. As well as locking the tailgate and doors, the system activates the engine immobilizer and steering column lock. If you prefer, you can also lock the car as using the standard key remote."
Link:
CanadianDriver.com First Drive of Cayenne
First Drive:
2003 Porsche Cayenne
Suckers.
While most of the car writers in the Toronto area abandoned sports cars at the first sign of winter - the vast majority of them needing space for families and stuff as well as all-weather capability during the cold months - I've been living it up schussing Porsches in and out of snowstorms, charging along icy roads, running circles around stuck SUVs. This past winter, I've probably spent more time in Porsches than most owners spend during the course of a year, cycling through the company's entire fleet of 911s and Boxsters, chasing wintertime thrills.
When our mindsets adjust for the change of seasons, after all, so do our automotive priorities. We look less for thrills than security; we trade exhilaration for comfort and convenience, responsiveness for stability and speed for safety features. Most of my journalistic colleagues thus find themselves in all-wheel-drive wagons, sedans, and SUVs, putting off sports-car pleasures to the summer, where they can be better enjoyed.
Too bad. Porsche only started running its press cars in the winter three years ago, and judging by the ease with which I booked all those cars, it seems like not a lot of people have noticed. It's mostly a psychological thing, I guess - bought as indulgences, these performance cars are rarely seen as the all-conditions, all-year-round tools that they really are. And try as the company might to change that image in North America - in Europe, where P-cars are even more expensive than they are here, people drive them all year - I guess it's still tough to see a Boxster or a 911 as something more than a summertime fling.
The new Cayenne SUV is likely to change all that, for it will be a superb wintertime performer, thanks to its all-wheel-drive (still rear-biased, of course, for tail-out antics if you want), Porsche Stability Management, huge disc brakes, and adjustable ground clearance. With the right tires fitted to its huge wheels - the 20-inch Michelin Diamaris tires we had for track testing would be out - nothing will be able to stop it, not even obstacles that would flummox most off-road vehicles.
It proved its abilities, too, on a challenging off-road test route that Porsche laid out for us at its new driving-school facility at Barber Mortorsports Park near Birmingham, Alabama. With low range engaged by the flick of a lever, and the center differential locked with another switch, the Cayenne proved unstoppable on some pretty awesomely difficult terrain, climbing 35-degree hills with ease and leaning over at 45 degrees without the engine hiccuping or any loss of stability. Off-road, this Porsche is, remarkably, the real deal, and is easily the equal of almost anything else out there, including the $104,000 Range Rover. Next year, for especially extreme types, an off-road technology package, with special 18" wheels, anti-roll bars that decouple automatically for more axle articulation, and a locking rear differential, becomes available.
Five seats and a decently, though not overly spacious interior with better build quality than any of the company's sports cars, will help more people justify buying a Porsche to their families. Plus there's also the value factor. Pound for pound, this SUV's a steal compared to the company's sports models - consider that about $80,000 will get you just a lightly-loaded two-seat 250-hp Boxster S when it nets 340 horses, all-wheel-drive, five seats, and a whack of safety features, as well as a lot more metal, in a Cayenne S. 450 horses in the $125,000 Cayenne Turbo undercut a less-powerful (but of course, still faster) 911 Turbo by more than $40,000. Seen that way, the Cayenne's actually a bit of a steal.
But though the Cayenne drives fantastic for an SUV, it still can't match the admittedly-untouchable watermark set by Porsche's sports cars, that feeling of lightness and nimbleness that make them a cinch to twirl through any condition. Compared to a 911, it feels heavy - in the steering and in the way that there's a fraction of hesitation when you ask it to change direction. Certainly, it'll run rings around most other SUVs out there - it remains the only one I've driven and enjoyed on a racetrack - but the Cayenne seems a bit of a cop-out, as it trades some of Porsche's trademark lithe, organic, ever-alive feel for more heft, security - and a huge slug of power to overcome the weight of all its goodies.
Which are numerous: heated leather seats and steering wheel, half a dozen cupholders, "servotronic" variable steering assitance, and a height-adjustable (and feel-adjustable, for sport or comfort) air suspension (optional on the S, standard on the Turbo). There's also a fantastic 350-watt 14-speaker Bose audio system featuring surround-sound programming, headlights that look around corners, and an optional extreme off-road package with a locking rear differential and sway bars that decouple for serious off-roading.
For those who want to drive a Porsche, and who need the space to haul around more than a couple of people at a time, there will be nothing that suits their needs better than a Cayenne, and I'm not here to stand in their way: it's a remarkable engineering achievement, and the Turbo is easily the fastest, most-communicative, SUV you can buy. The power is intoxicating, the steering is lovely, and the six-speed Tiptronic transmission does a great job.
The brakes are just awesome, too, with six-piston monoblock calipers in front and four-piston units in the rear - designed to sustain 25 panic stops from 90% of top speed without fade. Equipped with the optional 20-inch tires, the Cayenne also has more cornering grip than any other four-door out there. And it will do it all even when pulling a trailer of up to 3500 kg.
I know at least a couple of people that are merely enchanted by the IDEA of a Porsche SUV - the high-performance car you can drive in the winter! - and who want one but don't really need the space or the weight. To these people I'd say, be brave, and buy a Carrera or a Boxster instead.
Because the crucial thing the Cayenne's lacking, is the best, most indulgently offbeat part of all: the irony of driving a Porsche in winter. Drive a Cayenne in the winter and you're just another driver of a big, expensive, gas-guzzling SUV. Drive a Boxster or a 911 cabriolet, and especially if the weather is good enough to drop the top for some outdoor fun (like it was for a few days this winter) and you can be a one-of-a-kind, certifiable, his-brain-must-be-frozen sports-car LUNATIC.
I know which one I'd rather be.
I test drove a Cayenne S (without the salesman :p ) and it was very very very nice. Awesome handling and stopping power, and the sound of red-lining the engine was like music to my ears. I would love to try out the 450 hp Turbo, that would be scary. Radio sounded pretty good for a stock system, but it took me a long time to figure out how to do something as simple as changing the radio station. Another neat feature I discovered (accidentally while trying to adjust the driver's side mirror) was that you can automatically fold them in, good for avoiding scratches while off-roading. Even though it appears to have very good off-roading ability (low range and locking center diff, and close to 11" of ground clearance with optional air suspension) I would NEVER take such an expensive vehicle off-road for fear of scratching it. It would be great though for hauling the family to Disney World :)
Gator, maybe you're not used to anything costing over $21K, but most luxury cars have POWER-FOLDING mirrors! :D
Well Thai, being a Community college dropout and only working part-time at the local Pizza Hut, I'm not too familiar with these sorts of luxuries :p However, I'm moving back in with Mom and Dad soon so hopefully I'll be able to save up some money :D
Link:
USA Today Review of Cayenne
Summary:
Porsche Cayenne
What is it? Porsche's first sport-utility vehicle; midsize, four-door, four-wheel-drive, five-passenger SUV manufactured at a newly constructed Porsche factory in Leipzig, Germany, sharing a platform, but little else, with Volkswagen Touareg SUV.
How soon? On sale since March 15.
How much? Cayenne S starts at $56,665, including $765 destination charge. Cayenne Turbo starts at $89,665. Expect to pay full sticker price.
What's the drivetrain? Cayenne S is powered by 4.5-liter V-8 rated 340 horsepower at 6,000 rpm, 310 pounds-feet of torque at 2,500 rpm. Cayenne Turbo has twin-turbocharged 4.5-liter V-8 rated 450 hp at 6,000 rpm, 457 lbs.-ft. at 2,250 rpm. Transmission on both models is six-speed Tiptronic automatic with manual-shift mode. Both models have full-time, four-wheel drive that normally sends 62% of power to the rear wheels, 38% to the fronts and can shift 100% of power to either end. System has low-range gears and center differential lock for challenging off-road terrain.
What's the safety gear? The expected belts and bags, plus anti-skid control, anti-lock brakes, side-impact air bags and head-protection air curtains for front and rear occupants.
What's the rest? Traction control; leather upholstery; automatic dual-zone climate control; AM/FM/CD Bose stereo; power steering, brakes, windows, locks, mirrors, seats; remote-control locks; rear-window and outside-mirror defrosters; adjustable steering column; trip computer; 255/55R-18 tires on alloy wheels. Turbo model adds or substitutes air suspension; navigation system; high-intensity discharge headlights; heated seats and steering wheel; park alarm.
How big? Longer, wider and considerably heavier than BMW X5. Cayenne is 188.2 inches long, 75.9 inches wide, 66.9 inches tall, on a 112.4-inch wheelbase, weighing 4,949 pounds (S) or 5,192 pounds (Turbo), rated to tow 7,716 pounds. Rated to carry 1,791 pounds (S) or 1,598 pounds (Turbo) of people and cargo. Cargo space is listed as 19.1 cubic feet behind the rear seat, 65.5 cubic feet with the rear seat folded.
How thirsty? S is rated 14 miles per gallon in town, 18 on the highway. Test vehicle showed about 12 mpg in mostly suburban driving. Turbo is rated 13/18. Premium fuel is specified.
Who'll buy? At first, Porsche owners, 56% of whom already have SUVs and presumably can't wait to swap them for Porsche SUVs. After that, Porsche hopes to attract people who haven't owned a Porsche since their misspent youths or never have owned Porsches.
Overall: Impressive parts, disappointing whole.
Link:
Porsche Cayenne Review
2003 Porsche Cayenne Turbo
On a wink and a dare, Porsche heats up the luxury SUV category with fast, agile, pricey Cayenne
I’ve known this guy Billy Edwards for years, and I’ve always marveled at the tumbleweed quality of his escapades. He’s constantly long-legging it behind the wheel of some vehicle. Once it was the Borrow, Alaska-to-Key West, Florida, run in the newly debuted Ford Explorer back in the early ’90s. For many years it was the One Lap of America race in various Porsches. He’s a motorsports radio talk-show host, a performance driving instructor, a raconteur, a schemer in the most entertaining sense of the word.
This year, he was also my host, of a sort. “How’d you like to test-drive the new Porsche Cayenne Turbo?” he asked over the phone. He’d called to recruit me for the third running of Porsche’s Drive for Hope, a cross-country automotive trek to benefit the Hope Foundation’s cancer research efforts.
“You bet,” I answered instantly, winking with delight.
“I’ll slot you in for the Shenandoah leg. The off-road leg. You game for that?" There was a hint of dare in his voice.
“Heck yeah, I’m game,” I puffed back. “I’m up for that.” Or I would be. I had three months to think about it — about diving into the gorges of the George Washington National Forest behind the wheel of a coveted, nearly $90,000 hot-rod SUV — and to wonder why in the world anybody would do such a thing.
What the heck?
Of course, everyone throughout the automotive firmament is wondering precisely the same thing about Porsche’s own decision to build the Cayenne in the first place. Available with a choice of twin-turbo or non-turbo V-8s, the Cayenne is either a 450-hp SUV or a 340-hp one, an $89,000 SUV or a $56,000 one, respectively. The twin-turbo I drove for 14 hours and 400 miles on and off rural Virginia blacktop was bristling with technology: There’s dual-range four-wheel-drive; computerized descent control; 100-percent locking center differential; active suspension; ride-height control; adjustable suspension damping, tunable on-the-fly; six-speed Tiptronic gear shifting; electronic stability control; side-curtain airbags.
And, oh, did I mention 450 horsepower? This 5200-pound SUV is a 5.6-second sprinter from 0 to 60 mph. There’s an awful lot of physics in that accomplishment. It starts with Porsche’s first new V-8 since the departure of the company’s 928 grand tourer. There are 32 valves, twin overhead cams, two intercooled turbos, dry sump lubrication and Porsche’s VarioCam variable valve timing system. With 457 pound-feet of low-rpm torque (i.e., at 2250 rpm), two-and-a-half tons of steel and leather manage to trip the lights fantastic at two-seater sports car speeds.
Shenandoah switchbacks
Handling on curvy Shenandoah switchbacks was marvelous. As Billy navigated beside me, I paced a trio of identical Cayennes from Fancy Gap through Moscow, Va., then down into the Massanutten Valley of George Washington National Forest and back out again to wind up at the Fairmont Hotel in D.C. For every road and trail, there seemed an appropriate combination of suspension, powertrain and ride-height settings: Sport damping, six-inch ride-height and an open diff for the twisties; intermediate damping for the Interstate; almost eleven inches of ground clearance, locked differential, descent control, and “comfy-mode” shocks for the Massanutten trails and Fort Valley streams.
One minute, we’re blazing blue streaks down the Blue Ridge Parkway (“Sorry, officer.”), the next we’re transforming Virginia’s county roads into a personal Porsche paradise. Cayenne handling is almost perfectly taut and nearly infinitely reactive to changing road conditions. What’s more, Tiptronic clutchless gear changes via discreet steering wheel nubbins mean instant reactions to curves and straightaways. Sure, you can gear-change with the console shifter; but with the nubbins, you peck your way immediately through sixth, fifth, fourth, third then back again as the roads alternately coil and unroll before you. I had a blast; and I basked in some of the smoothest fast driving I’ve ever experienced outside a racetrack.
For good reason, it seems, does Porsche equip the Cayenne (and its Carreras too, for that matter) with an electronic tell-tale that you can set for any speed. Those of us who despise cruise control can very much appreciate the polite alarm that warns when you’ve tipped past, say, 85 miles an hour. “Do more if you dare,” the Cayenne seems to say (and a near double-dare of this speed is not out of the question); “just don’t say I didn't warn you.”
Off-pavement goods
Then suddenly, you run out of road. Flick the console controls to lock the diff, boost air ride to maximum ground clearance and downshift to low-low. For three-and-a-half hours we plied the rocky folds of the Shenandoah Valley in three Cayennes with roof toppers and Aprilia motorscooters rigged to the back bumper. We spent a quarter of the day off-road. To go eight miles. Through streams up to 22 inches deep. Up boulder-strewn inclines. Down oozing, muddy defiles. Cayenne’s computerized “traction brain” distributed locomotive force to the wheels that wanted it and prevented lock-up when tires tried to slide.
Porsche makes a point of describing Cayenne as an “off-pavement” vehicle so as not, I suspect, to invite dismissive sneers from touchy owners of lumpen Hummers. Fair enough; but Cayenne is positively magisterial on the trail compared to a BMW X5 4.6i or Mercedes-Benz’s ML500/ML55 duo. And M-B’s mountain-goat G-Wagen and Land Rover’s toney Range Rover deliver nowhere near the Porsche’s horsepower and handling.
It’s as if Porsche were laying out a dare to all SUV rivals, whatever the price: “C’mon...let’s see what ya got.” For the life of me, I don’t know what other SUV can touch the Cayenne in terms of braggadocio quotient. Yet it dawns on me that Cayenne itself may be the answer to a dare within Porsche’s own ranks: “C’mon...let’s see if we can build the world fastest, most complex SUV.” Now that they have done it, they’re daring the rest of the world to notice, even to care.
VW gets tough with Touareg
New luxury SUV features top-class quality, performance and off-road prowess
By Richard Russell
Thursday, November 14, 2002
BARCELONA, Spain - Volkswagen's first shot at the sport-utility market is lofty, aimed over the heads of the mainstream players, directly at the luxury segment. The 2004 Touareg will appear in VW stores next spring or summer as part of Volkswagen's effort to offer its legions of loyal customers a chance to move up within the brand. And more significantly, as a shot across the bow of Audi, BMW and Mercedes-Benz, which have been moving into VW's territory by offering less expensive models in Europe.
Marketing and competitive reasons aside, VW is serious about this vehicle and has put considerable engineering thought and resources behind the effort. Developed in conjunction with the upcoming Porsche Cayenne, the Touareg is a big 5,000-plus pound vehicle equipped with a full slate of next-generation technology and 6-, 8-, 10- or 12-cylinder engines.
Several hundred kilometres at the wheel of a variety of pre-production models gave the distinct impression the Touareg will be at or near the top of the class in terms of quality, interior refinement, engineering and on-road manners. But it will clearly go to the front of the pack when it's time to go off-road. VW also hopes to have a distinct edge on the others in terms of drivetrain choice, standard equipment level and price. The goal is to bring the Touareg to Canada around $50,000 for a well-equipped base version.
All Touaregs come with a modified version of VW's 4Motion all-wheel drive system, electronically controlled locking centre and rear differentials and a 2-speed transfer case. A 3.2-litre V6 and 4.2-litre V8 will be sourced from Audi; a 5.0-litre V10 from heaven and the 6.0-litre W12 in-house. The transmission of choice across the board is a new 6-speed automatic with Tiptronic and optional shift paddles behind the wheel. We found the latter all but useless, especially off-road since they are attached to the column and don't move with the wheel.
We drove Touaregs equipped with the V6 and V10 engines. The former proved smooth, quiet, modern and reasonably capable considering the size and weight of this beast. We also spent a few quality hours with a twin-turbo V10 diesel. The V10 diesel produced an impressive 313 horsepower, mind-boggling 555 lb-ft of torque and absolutely stunning performance. When we left Spain, a European colleague was cooling his heels in jail after being nabbed for 245 km/h in one of the V10s! Let's start a movement - get down to your VW dealer and start a petition to bring this engine to Canada. Not only in the Touareg - VW could sell complete engines to CN to replace locomotives!
Ride height is a big issue with SUVs that purport to be able to play equally well both on- and off-road. The Touareg will see duty at high speed on the Autobahn and crawling around the outback at single digit speeds. So the wizards in the lab developed an automatic height adjustment system covering a range from 160 mm to 300 mm depending on speed, conditions and settings. It automatically lowers the ride height in stages: at 125 km/h and 180 km/h. We felt it our duty to verify both. The system also includes a step-in mode to bring the Touareg to its knees when parked for easier access to people and cargo spaces. There are electronic assists to hold it on an upward slope and help it crawl back down at walking speeds - with both feet clear of the pedals. It is designed to climb a 45-degree slope, a 35-degree side slope (perhaps the most attention-getting of all off-road exercises) and tackle 28-degree approach and departure angles. The latter can be extended to 30 degrees if jacked up with the adjustable suspension. It is capable of fording 500 mm of water (580 mm with the suspension raised). All this controlled by a pair of rotary knobs atop the centre console.
Inside, the 5-passenger Touareg takes VW's typical attention to detail to new heights. Incredibly narrow panel gaps and top quality leather, wood, metal and plastic result in a distinctly upmarket and stylish look and feel. The seats are big, supremely adjustable and all-day comfortable. As befits a vehicle of this class, there is a full array of comfort, convenience and safety equipment, including four-zone climate control, front, thorax and side curtain airbags, etc.
On the road, the big SUV feels solid and extremely stable. At any sane speed there is an almost complete lack of wind and road noise. The ride is supple and well controlled over both minor and major interruptions and the steering is communicative and linear. The Touareg is a big, heavy, tall vehicle so it understeers when pressed into a turn, but leans very little and sticks very well. The V6, with less weight up front was better balanced, but the V10 made up for it on the straights! The ability to send power to all four wheels means you can get back on the throttle early and it pulls out of the corner with authority, especially with the diesel's awesome torque. The massive brakes - 6-piston Brembos up front - are not only powerful, but progressive and capable of hauling this heavy monster down from silly speeds repeatedly, with no fade. During an extensive session at a special facility owned and developed by world rally champ Carlos Sainz, the Touareg easily handled a tortuous course that caused most passengers to bail and many to seek a washroom. Extreme angles, awesome changes in elevation, deep rivers and nothing but sky outside the window were the norm. On standard 18-inch, all-season tires the Touareg laughed it all off thanks to a full array of techno-trickery, including drive-by-wire throttle that eliminates the super-sensitive jumpiness of off-roading in low range.
Volkswagen is hoping the Touareg will take the company places it's never been: into the hearts and minds of luxury car buyers. It is more than capable of climbing mountains, but the bigger hill might be that of convincing Acura, BMW, Lexus and Mercedes customers to put VW on their shopping list.
Immediate competition:
Acura MDX, BMW X5, Lexus RX300, Mercedes-Benz M-Class
Ambrose67
